Tune Schraubwurger Seatpost Collar
Weight 9 grams
Collar Material 7075 Aluminum
Bolt Material Titanium
Tune Schraubwurger Seatpost Collar 30.0 mm, Black $40.00 In Stock
Tune Schraubwurger Seatpost Collar 31.8 mm, Black $40.00 In Stock
Tune Schraubwurger Seatpost Collar 34.9 mm, Black $40.00 Notify Me When Available
Tune Schraubwurger Seatpost Collar 34.9 mm, Blue $40.00 In Stock
Tune Schraubwurger Seatpost Collar 34.9 mm, Gold $40.00 Notify Me When Available
Tune Schraubwurger Seatpost Collar 34.9 mm, Green $40.00  1 Remaining
Tune Schraubwurger Seatpost Collar 34.9 mm, Orange $40.00 In Stock
Tune Schraubwurger Seatpost Collar 34.9 mm, Pink $40.00  1 Remaining
Tune Schraubwurger Seatpost Collar 34.9 mm, Purple $40.00  1 Remaining
Tune Schraubwurger Seatpost Collar 34.9 mm, Red $40.00 In Stock
Tune Schraubwurger Seatpost Collar 38.0 mm, Black $40.00 In Stock
Tune's precise attention to detail makes for immaculately crafted products. Affording no weight penalty, the Schraubwurger seatpost collar is carefully machined of 7075 aluminum, with a single titanium bolt to clamp, at a competitively low weight of only 9 grams. An etched Tune logo adorns the surface of the anodized collars, which are available in an assortment of colors.
The Tune Schraubwurger seatpost collar bolt requires a T25 Torx bit to fasten. Use of a torque wrench is highly recommended, and should be fastened to 5Nm.
Comment on Tune Schraubwurger Seatpost Collar
