Tune Princess Front Disc Hub
Tune Princess Front Disc Hub Black, 32 hole$330.00 Notify Me When Available
Weight105 grams
Bearing Size6803 (2)
Axle Diameter17 mm
Shell, Axle Material7075 aluminum
Disc Mount6 bolt ISO
Available Drillings28, 32 hole
Available Colorsblack, red, pink
Wheel Building Dimensions
Left Flange Diameter56 mm
Right Flange Diameter56 mm
Center to Left Flange26 mm
Center to Right Flange35 mm
The Princess is a weight tuned version of Tune's King disc hub; one of the lightest front disc hubs available. The Princess receives extra machining on the outer surface of the hub shell, and a circumferential carbon fiber wrap on the flanges to increase their tensile strength. An extra large 17mm axle ensures maximum front end stiffness. This simple, durable design allows conversion between quick release and 15 mm thru axle versions. The Princess is available in several anodized colors, with Tune's logo laser etched on the hub shell.
The Tune Princess is 100% designed and manufactured in Germany to the highest quality standards.
Installation/Assembly
We recommend that wheels with Tune hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Links
Tune Prince Rear Disc Hub - Tune's logical matching rear hub to the Princess.
Comment on Tune Princess Front Disc Hub
