Tune MIG 45 Front Hub
Tune MIG 45 Front Hub Black/Carbon 16 Hole$300.00  1 Remaining
Tune MIG 45 Front Hub Black/Carbon 20 Hole$300.00  1 Remaining
In order to properly load spokes into the Tune Mig 45's flanges, the carbon axle must be removed and then reinstalled using a specially-designed service kit. For this reason we will not sell the Mig 45 independent of a complete wheel build. For more information, please contact us directly or submit a custom wheel build request here.
Weight50 grams
Bearing Size6802 (2)
Axlecarbon, 15 mm
Tube7075 aluminum
Flanges7075 aluminum and carbon
Available Drillings16, 20 hole
Available Colorsblack, red
Wheel Building Dimensions*
Flange Diameter28 mm
Center to Flange36 mm
*the design of this hub requires straight pull spokes
The Tune Mig 45 is almost as much a showpiece as it is a functional and lightweight hub. Using the same basic three piece floating flange design of Tune's mainstay Mig 70, The Mig 45 incorporates straight pull, carbon reinforced flanges and a full length 15 mm carbon axle. The substitution of this carbon material shaves an incredible 25 grams off an already lightweight design, and adds a modicum of aesthetic appeal as well. The straight pull flanges create a secure foundation for spoke heads to minimize long term spoke fatigue, along with a wide bracing angle for laterally stiff wheel builds. The 7075 aluminum hub shell components are expertly machined and anodized, and the hub shell is tastefully etched with the Tune logo.
The Tune Mig 45 is 100% designed and manufactured in Germany to the highest quality standards.
Comment on Tune MIG 45 Front Hub
