| Weight | 187 grams |
| Bearings | 6802 (1), Tune XOT (1), 6902 (1) |
| Material | 7075 aluminum |
| Available Drillings | 20, 24, 28, 32 hole |
| Available Colors | black, blue, gold, orange, pink, red, white |
| Wheel Building Dimensions |
| Left Flange Diameter | 41.0 mm |
| Right Flange Diameter | 54.4 mm |
| Left Flange to Center | 39.0 mm |
| Right Flange to Center | 17.0 mm |
The Mag 180 has long held as the standard by which all lightweight rear hubs were measured. The 180 has recently been surpassed in weight by several manufacturers, yet remains one of the most affordable lightweight rear hubs. Weight savings features on the 180 include a machined aluminum freehub body, a stiff 15 mm aluminum axle, and titanium drive ring. The Mag 180 also features Tune's proprietary XOT bearing, a combination 6802/6902 bearing with a shared inner race to increase stiffness at the freehub and hub shell joint.
Assembly
We recommend that wheels with Tune hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Links
The Tune Mag 180 is featured in Madcow's hub review on our forum here.
