Tune MAG 170 Rear Hub
Weight 170 grams
Bearings 6803 (1), 6903 (1), 6803 (2)
Axle Diameter 17 mm
Available Drillings 24, 28 hole
Hub Shell Material 7075 aluminum
Use road, cyclocross
Drivetrain Compatibility
ShimanoAll 11 and 10 speed
SramAll 10 speed
CampagnoloAll 11 and 10 speed
Wheel Building Dimensions
Left Flange Diameter 41 mm
Right Flange Diameter 54 mm
Left Flange to Center 36.0 mm
Right Flange to Center 18 mm
Tune MAG 170 Rear Hub Black, 20 Hole, Shimano $410.00 Notify Me When Available
Tune MAG 170 Rear Hub Black, 24 Hole, Campagnolo $410.00 Notify Me When Available
Tune MAG 170 Rear Hub Black, 24 Hole, Shimano $410.00  2 Remaining
Tune MAG 170 Rear Hub Black, 28 hole, Campagnolo $410.00  1 Remaining
Tune MAG 170 Rear Hub Black, 28 Hole, Shimano $410.00  1 Remaining
Tune MAG 170 Rear Hub Blue, 24 Hole, Campagnolo $410.00 Notify Me When Available
Tune MAG 170 Rear Hub Blue, 24 Hole, Shimano $410.00 Notify Me When Available
Tune MAG 170 Rear Hub Gold, 24 Hole, Shimano $410.00 In Stock
Tune MAG 170 Rear Hub Red, 24 Hole, Campagnolo $410.00  1 Remaining
Tune MAG 170 Rear Hub Red, 24 Hole, Shimano $410.00  1 Remaining
Tune MAG 170 Rear Hub Red, 28 Hole, Shimano $410.00 Notify Me When Available
Tune MAG 170 Rear Hub White, 24 Hole, Campagnolo $415.00 Notify Me When Available
Tune MAG 170 Rear Hub White, 24 Hole, Shimano $415.00  1 Remaining
Tune MAG 170 Rear Hub Mag 170 Ceramic Upgrade $135.00 In Stock
The MAG 170 is Tune's latest iteration of their lightweight rear road hub design. When compared to its predecessor, the MAG 180, several key improvements become apparent. The most dramatic change is the move from a 15 mm axle to a 17 mm aluminum axle. This increase in diameter helps to save weight while increasing the stiffness of the hub assembly. In order to accommodate the larger axle size, Tune had to redesign the rest of the hub. The hub shell itself has slightly increased in diameter, along with the drive mechanism. And in redesigning the hub shell, Tune opted to improve the flange spacing for better spoke bracing angles, ultimately leading to stronger, laterally stiffer wheel builds.
Internally, each bearing has been effectively downsized to save weight and to fit the larger axle. Tune has also opted to abandon its XOT double bearing and preload mechanism, which greatly simplifies axle removal and hub overhaul.
Tune MAG 170 hubs are designed and manufactured with pride in Germany.
Assembly
We recommend that wheels equipped with Tune hubs be assembled by an experienced wheel builder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Links
The MAG 170 is featured in our Enve / Tune Smart System 6.7 Wheelset.
Comment on Tune MAG 170 Rear Hub
