Tune
Specifications Weight, 34 tooth 34 grams Weight, 36 tooth 35 grams Weight, 39 tooth 32 grams Weight, 50 tooth 79 grams Weight, 53 tooth 82...
$75.005 options.View
The Starkes Stuck is one of the most popular choices for a lightweight, yet very solid seatpost for mountain bike and road applications. While the...
$160.0022 options.View
Specifications Weight 55 grams/pair Mounting Angle 9 degrees Grip Diameter 27 mm Body Material 7075 aluminum Fastener Material 6/4...
$105.0010 options.View
Tune's conventional headset for road and MTB use. Weighs 79g • Material : cups: 7075 T6 aluminum, cap: carbon. • Construction : conventional...
$155.0010 options.View
Specifications Weight89 gramsMaterial, Cups7075 T6 aluminumStack Height8.9 mmSHIS FitZS44/28.6|ZS56/40 Detail The Tune Bubi is a tapered 1-1/8" to...
$200.001 options.View
Specifications Weight, Headset Only63.5 gramsWeight, Top Cap and Bolt 5.0 gramsWeight, Expander9.6 gramsMaterial, Cups7075 T6 AluminumStack Height8.9...
$155.002 options.View
Specifications Weight 99 grams Material 7075 aluminum Bearing Sizes 6802, 6805 Available Spoke Drillings 28, 32 Wheel Building...
$220.007 options.View
Specifications Weight74 gramsAvailable Diameters30.25, 34.9, 38.35 mmMain Tube Material7075 aluminumBolt MaterialtitaniumSetback1 mm (30.25), 2 mm...
$170.0013 options.View
Specifications Weight 19 grams, including mounting hardware Details This design fits either a 500 or 750ml bottle securely, utilizing a large...
$70.000 in stock.View
The Tune carbon top cap and bolt is the one of lightest such assemblies carried at Fair Wheel Bikes. It is simple, effective, and elegant. The carbon...
$20.000 in stock.View
Tune has brought together aluminum, titanium, and carbon fiber to create one of the lightest and prettiest quick release road skewers available....
$120.0010 options.View
Specifications Weight40 gramsMaterial7075 aluminum, carbon fiberFork OptionsFox, DT, Rock Shox, MarzocchiColorsBlack, Blue, Gold, Green, Orange,...
$150.005 options.View
Tune has brought together aluminum, titanium, and carbon fiber to create one of the lightest and prettiest quick release mountain skewers available....
$130.0010 options.View
Specifications Weight9 gramsSteerer ID Fit24.0 - 25.5 mmPlate Material7075 T6 aluminumExpander Materialsilicone rubber Detail Tune's Gum Gum is one...
$17.000 in stock.View
Specifications Weight115 gramsBearing Size6803 (2)Axle Diameter17 mmShell, Axle Material7075 aluminumDisc Mount6 bolt ISOAvailable Drillings28, 32...
$220.009 options.View
Specifications Weight 97 grams Material carbon, leather Weight Limit 90kg. (200lbs.) Details The Kom-Vor is an extremely comfortable and...
$275.005 options.View
Specifications Weight205 gramsBearing Size6803 (1), 6903 (1), 6803 (2)Axle Diameter17 mmAvailable Drillings28, 32 holeDisc MountingISO 6-bolt Wheel...
$440.008 options.View
Kong X-12 Details CompatibilityX-12 (142+) Weight208 grams Bearing Size6803 (1), 6903 (1), 6803 (2) Axle Diameter17 mm Available Drillings28, 32 hole...
$440.003 options.View
Specifications Weight170 gramsBearings6803 (1), 6903 (1), 6803 (2)Axle Diameter17 mmAvailable Drillings24, 28 holeHub Shell Material7075...
$410.0011 options.View
In order to properly load spokes into the Tune Mig 45's flanges, the carbon axle must be removed and then reinstalled using a specially-designed...
$300.002 options.View
Specifications Weight75 gramsBearings6802 (2)Shell Material7075 aluminum Wheel Building Dimensions Flange Diameter37.5 mmFlange to Center35 mm...
$185.0013 options.View
Specifications Weight105 gramsBearing Size6803 (2)Axle Diameter17 mmShell, Axle Material7075 aluminumDisc Mount6 bolt ISOAvailable Drillings28, 32...
$330.001 options.View
Tune's 0.3 gram Pulsar spoke magnet is manufactured from a highly magnetic rare earth metal. Using such material allows the magnet to be made...
$10.0019 in stock.View
Specifications Weight9 gramsCollar Material7075 AluminumBolt MaterialTitanium Detail Tune's precise attention to detail makes for immaculately...
$40.005 options.View
The Singlespeeder fits the needs of the weight conscious singlespeeder. You can get rid of that heavy disc hub and heavy, ovaled freewheel that...
$600.002 options.View
Specifications Weight, BB30 68/7358 gramsWeight, BSA 68/7392 gramsBearingssteel cartridge, 6806 (2) Detail These bottom bracket bearing kits are...
$70.002 options.View
Specifications Weight, without BB625 gramsMaterial7075 aluminumSpindle Diameter30 mmQ-Factor167 mmBCD104/64Chainrings44, 32, 22 toothAvailable Crank...
$700.003 options.View
Weight, without BB 632 grams Material 7075 aluminum Spindle Diameter 30 mm Q-Factor 1632 mm BCD 110 Chainrings 50 / 34 tooth Available...
$700.002 options.View
Specifications Weight95 gramsColorsBlack, Blue, Red, Yellow, WhiteRail SizeOval 10mmRail MaterialCarbon/Kevlar Detail For years this was considered...
$300.005 options.View
The Tune Verhüterli is designed for use with carbon steerer tubes as a super lightweight replacement for the traditional expander plug, top cap, and...
$27.0018 in stock.View
Specifications Weight 90g Details Fill out your water bottle arsenal with this addition, provided by Tune and manufactured by Tacx. This is a...
$10.005 in stock.View
Specifications Weight28 gramsCollar Material7075 aluminumBold and Nut Material7075 aluminumLever Material6/4 titanium Detail Wurger translates from...
$70.001 options.View
Specifications Weight5.0 gramsAvailable Sizes28.6, 30.0, 31.8, 34.9, 36.4, 38.0 mmRider Weight Limit80 kg (176 lbs) Detail Tune's Skyline series of...
$100.001 options.View
Tune's carbon fiber shifter clamp bands, manufactured in Germany by Bicycle Tuning Parts, are the ultimate weight tuning part. Invisible under the...
Specifications Weight, without pads 45 grams/set of four Detail These carbon pad holders are specially manufactured for Tune by Bicycle Tuning...
$175.001 in stock.View
Specifications Weight, 95 mm105 gramsWeight, 110 mm120 gramsRise+/- 8 degreeStem Material7075 aluminumBolt Material6/4 titaniumHandlebar Clamp31.8...
$230.004 options.View
Specifications Weights, 110mm128 gramsAngle8 degreeDiameters25.4Lengths95mm, 110mmColorsOrange, Black, Red Detail The 'Geiles Teil' stem from Tune is...
$168.00 $126.00Save: $42.00 off
2 options.View
Specifications Weights, 110mm129 gramsAngle8 degreeDiameters26.0Lengths60mm, 85mm, 95mm, 110mmColorsPink, Orange, Black, Blue, Red Detail The 'Geiles...
6 options.View
Specifications Weights, 85mm128 gramsAngle8 degreesDiameters31.8Lengths85mm, 95mm, 105mm, 115mmColorsPink, Orange, Black, Blue, Red, Purple, Forest...
4 options.View
