Tune Kong X-12 Disc Rear Hub
Tune Kong X-12 Disc Rear Hub Black, 32 Hole $440.00 Notify Me When Available
Tune Kong X-12 Disc Rear Hub Red, 32 Hole $440.00 In Stock
Tune Kong X-12 Disc Rear Hub White, 32 Hole $450.00 Notify Me When Available
Kong X-12 Details
CompatibilityX-12 (142+)
Weight208 grams
Bearing Size6803 (1), 6903 (1), 6803 (2)
Axle Diameter17 mm
Available Drillings28, 32 hole
Disc MountingISO 6-bolt
Wheel Building Dimensions
Left Flange Diameter56 mm
Right Flange Diameter56 mm
Center to Left Flange37 mm
Center to Right Flange20 mm
Tune's Kong X-12 hub is in response to the X-12, or 142+, standard being used by companies like Trek, Specialized and Santa Cruz. The Kong X-12 is built upon the already popular Kong rear hub design, which is one of lightest rear disc hubs available today. At 208g, the Kong X-12 features a large 17 mm aluminum axle, an aluminum freehub body, and durable hardened steel pawls. In typical Tune fashion, these hubs are available in a host of bright anodized colors as well as powdercoated white.
Assembly
We recommend that wheels with Tune hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Comment on Tune Kong X-12 Disc Rear Hub
