Tune Kong Rear Disc Hub
Tune Kong Rear Disc Hub Black, 28 Hole $440.00 In Stock
Tune Kong Rear Disc Hub Black, 32 Hole $440.00 In Stock
Tune Kong Rear Disc Hub Red, 28 Hole $440.00 Notify Me When Available
Tune Kong Rear Disc Hub Red, 32 Hole $440.00 In Stock
Tune Kong Rear Disc Hub White, 28 Hole $450.00 Notify Me When Available
Tune Kong Rear Disc Hub White, 32 Hole $450.00 In Stock
Weight205 grams
Bearing Size6803 (1), 6903 (1), 6803 (2)
Axle Diameter17 mm
Available Drillings28, 32 hole
Disc MountingISO 6-bolt
Wheel Building Dimensions
Left Flange Diameter56 mm
Right Flange Diameter56 mm
Center to Left Flange37 mm
Center to Right Flange20 mm
Tune's Kong rear hub is one of lightest rear disc hubs available today. 205 grams of German precision, the Kong features a large 17 mm aluminum axle, an aluminum freehub body, and durable hardened steel pawls. In typical Tune fashion, these hubs are available in a host of bright anodized colors as well as powdercoated white.
Assembly
We recommend that wheels with Tune hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Comment on Tune Kong Rear Disc Hub
