Tune King / Kong Fatbike Hubs
Sign Up For Our Newsletter
You're Signed Up!
Weight, Front139 grams
Weight, Rear240 g
Bearing Size6903, 6803
Hub Spacing, Front135 mm
Hub Spacing, Rear170 / 177 mm
Axle Diameter17 mm
Disc MountISO 6 bolt
Wheel Building Dimensions, Front
Flange Diameter55.5 mm
Center to Left Flange40.2 mm
Center to Right Flange41.3
Wheel Building Dimensions, Rear
Flange Diameter55.5
Center to Left Flange37.8 mm
Center to Right Flange38.7 mm
Tune King / Kong Fatbike Hubs Fat King, 32 hole, Thru, Black $240.00 In Stock
Tune King / Kong Fatbike Hubs Fat King, 32 hole, QR, Black $240.00 Contact Us For More Information
Tune King / Kong Fatbike Hubs Fat Kong, 32 hole, 170 mm, QR, Black $530.00  1 Remaining
Tune King / Kong Fatbike Hubs Fat Kong, 32 hole, 177 mm, Thru Axle, Black $530.00  1 Remaining
Tune King / Kong Fatbike Hubs Fat Kong, 32 hole, 170 mm, QR, XX1,Black $530.00 Contact Us For More Information
Tune King / Kong Fatbike Hubs fat Kong, 32 hole, 177 mm, Thru Axle, XX1, Black $530.00 In Stock
Details
After years of working with Tune's King and Kong hubs we quickly decided who we wanted to make hubs for us and our upcoming fat bike projects. The Fat King and Fat Kong hubs brings Tune's positive engagement, strength and weight to a wider 170/135mm standard. Each hub body is expertly CNC machined from 7075 Alloy then polished and anodized for a clean smooth look. The three pawl cassette body has fairly quick thirteen degree engagement by using 27 teeth. Both hub flanges are spaced out to build a dishless wheel this will make your wheels easy to build while increasing their strength.
Compatibility
The King / Kong hubs are compatible with a variety of drive-trains and axle options. Both hubs are compatible with 9mm standard quick release or a 12mm through axle with the right end cap kits. The rear hub is compatible with either Shimano 9, 10 or 11 speed or Sram XX1 drive-trains.
Wheel building
We recommend that wheels with Tune hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Comment on Tune King / Kong Fatbike Hubs
