Tune King Front Disc Hub
Tune King Front Disc Hub 15mm Thru Axle Adapter$75.00 Notify Me When Available
Tune King Front Disc Hub Black, 28 Hole$220.00 Notify Me When Available
Tune King Front Disc Hub Black, 28 Hole, 15 mm Thru Axle$220.00 Notify Me When Available
Tune King Front Disc Hub Black, 32 Hole$220.00  1 Remaining
Tune King Front Disc Hub Black, 32 Hole, 15 mm Thru Axle$220.00 Notify Me When Available
Tune King Front Disc Hub Red, 28 Hole$220.00  1 Remaining
Tune King Front Disc Hub Red, 32 Hole$220.00 Notify Me When Available
Tune King Front Disc Hub White, 28 Hole$230.00  1 Remaining
Tune King Front Disc Hub White, 32 Hole$230.00  1 Remaining
Weight115 grams
Bearing Size6803 (2)
Axle Diameter17 mm
Shell, Axle Material7075 aluminum
Disc Mount6 bolt ISO
Available Drillings28, 32 hole
Available Colorsblack, red, white
Wheel Building Dimensions
Left Flange Diameter56 mm
Right Flange Diameter56 mm
Center to Left Flange26 mm
Center to Right Flange35 mm
The King front disc hub from German manufacturer Tune is at once lightweight, strong, and attractive. After several years of production, the King remains one of the lightest and most durable front hub options, with a price that is equally competitive. For 2010, Tune has updated this design to allow conversion between quick release and 15 mm thru axle versions. As a result, these newer hubs are also about 20 grams lighter with a larger diameter axle for improved front end stiffness. The King is available in several anodized colors, with Tune's logo laser etched on the hub shell. The white hubs are given a durable powdercoat.
Tune King hubs are 100% designed and manufactured in Germany to the highest quality standards.
Installation/Assembly
We recommend that wheels with Tune hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Links
Tune Kong Rear Disc Hub - Tune's logical matching rear hub to the King.
Comment on Tune King Front Disc Hub
