Tune DC14 Road Skewers
Sign Up For Our Newsletter
You're Signed Up!
Weight33 grams
Front Axle7075 aluminum
Rear Axle6V4 titanium
LeverCarbon/7975 aluminum
Useroad only
Tune DC14 Road Skewers Black $135.00 In Stock
Tune DC14 Road Skewers Blue $135.00  2 Remaining
Tune DC14 Road Skewers Forest Green $135.00 In Stock
Tune DC14 Road Skewers Froggy Green $135.00 In Stock
Tune DC14 Road Skewers Gold $135.00 Notify Me When Available
Tune DC14 Road Skewers Orange $135.00 In Stock
Tune DC14 Road Skewers Pink $135.00 In Stock
Tune DC14 Road Skewers Purple $135.00 In Stock
Tune DC14 Road Skewers Red $135.00 In Stock
Tune DC14 Road Skewers Silver $135.00 Notify Me When Available
Details
Tune has brought together aluminum, titanium, and carbon fiber to create one of the lightest and most attractive quick release road skewers available.
Using several clever and elegant design features, the DC14 achieves an incredible weight of 33 grams. Perhaps the most unique and striking feature of the DC14 skewers are the thin but strong carbon lever ends. The lever bases and adjusting caps are elegantly machined from high strength aluminum alloys, with knurls added to the dropout contacts and adjusting nut for maximum security and easy adjustment. The lack of torsional load on the front hub allows Tune to use an incredibly light aluminum axle, while the rear axle is constructed from 6/4 titanium in a tension screw design for maximum strength where it's needed. The levers and adjusting caps are elegantly machined from high strength aluminum alloys.
Installation and Maintenance
Tune's skewer design operates the same as most other skewers, with a simple closure of the lever to secure the hub in the dropouts. However, the ball-and socket eccentric cam allows for the skewer tension to be modified once the lever is closed. Simply rotate the lever clockwise or counterclockwise to increase or decrease the clamping force. Tune impregnates the socket plate with molybdenum disulfide (i.e. graphite) to reduce friction in the cam. For this reason, the cam does not require lubrication, and should be kept clean and dry. The skewer threads should be occasionally lubricated with a light grease to prevent corrosion and allow for smooth adjustment.
