Tune Cannonball Lefty Front Hub
Tune Cannonball Lefty Front Hub Black, 28 Hole$220.00 Notify Me When Available
Tune Cannonball Lefty Front Hub Black, 32 Hole$220.00 Notify Me When Available
Tune Cannonball Lefty Front Hub Froggy Green, 28 Hole$220.00  1 Remaining
Tune Cannonball Lefty Front Hub Froggy Green, 32 Hole$220.00 Notify Me When Available
Tune Cannonball Lefty Front Hub Red, 28 Hole$220.00  2 Remaining
Tune Cannonball Lefty Front Hub Red, 32 Hole$220.00  2 Remaining
Tune Cannonball Lefty Front Hub White, 32 Hole$240.00 Notify Me When Available
Weight 99 grams
Material 7075 aluminum
Bearing Sizes 6802, 6805
Available Spoke Drillings 28, 32
Wheel Building Specifications
Left Flange Diameter 55 mm
Right Flange Diameter 40 mm
Left Center to Flange 20 mm
Right Center to Flange 37 mm
*Tune restricts lacing pattern to 2x or greater on Cannonball hubs.
The growing popularity of Cannondale's Lefty front suspension has convinced several boutique manufacturers to produce front hubs compatible with the Lefty design. The advantage of a these design-specific hubs is that a wheel can be built to the rider's specifications for weight savings with optimal strength and durability. Tune's Cannonball hub, paired with a Tune Kong rear hub, is a great option for Cannondale riders looking to build up a special wheelset for their rigs.
The Cannonball uses a stout yet minimalist design to reach a sub-100 gram weight while achieving high marks in aesthetic appeal. The semi polished hub shell and high quality color anodizing with laser etched graphics complete an unmistakable Tune look. This is a disc brake hub with a standard ISO six bolt pattern. Tune assigns no rider weight limit for the Cannonball hub.
All Tune hubs are manufactured in Germany to the highest quality standards, and are backed by a two year warranty against material and manufacturing defects.
Assembly and Installation
We recommend that wheels built with Tune hubs be assembled by an experienced wheel builder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheel build here. Please note that a Lefty dummy axle is required to properly build and true a wheel built with the Cannonball hub.
Installation of the Cannonball hub onto a Lefty fork is easy; simply slide the hub onto the fork's axle and torque the mounting bolt to 6-8 Nm. Tune recommends the use of Loctite 243 or 262 on the mounting bolt's threads.
Comment on Tune Cannonball Lefty Front Hub
