Tune Bubu Semi Integrated Headset
Tune Bubu Semi Integrated Headset Black$155.00  1 Remaining
Tune Bubu Semi Integrated Headset Red$155.00  1 Remaining
Weight, Headset Only63.5 grams
Weight, Top Cap and Bolt 5.0 grams
Weight, Expander9.6 grams
Material, Cups7075 T6 Aluminum
Stack Height8.9 mm
Headtube Compatibility44 mm semi-integrated press fit
The Tune Bubu is a lightweight, semi-integrated headset of elegant design and flawless functionality. The Bubu's aluminum cups, crown race, and bearing cover are accurately machined for weight savings, and mated with high quality, angular contact steel cartridge bearings for durability.
Included with each Bubu Headset is a carbon top cap and aluminum bolt, as well as Tune's cleverly designed Gum Gum expander plug.
Tune's headsets are designed and manufactured with pride in Germany.
Installation/Assembly
Installation of this headset's cups will require a headset press with appropriate adapters. The crown race is split for easy, tool-free installation. Care should be taken when fitting the delicate plastic upper bearing cover.
Comment on Tune Bubu Semi Integrated Headset
