Tune Aluminum Chainrings
Tune Aluminum Chainrings 110 BCD, 36 Tooth$75.00 Notify Me When Available
Tune Aluminum Chainrings 110 BCD, 50 Tooth$86.00 Notify Me When Available
Tune Aluminum Chainrings 130 BCD, 39 Tooth$75.00 Notify Me When Available
Tune Aluminum Chainrings 130 BCD, 53 Tooth$88.00 Notify Me When Available
Tune Aluminum Chainrings 110 BCD, 34 Tooth$75.00 In Stock
Weight, 34 tooth 34 grams
Weight, 36 tooth 35 grams
Weight, 39 tooth 32 grams
Weight, 50 tooth 79 grams
Weight, 53 tooth 82 grams
Material 7075 aluminum
Available BCDs 110, 130, 135 mm
Tune's chainrings are CNC milled from sheets of strong and light 7075 aluminum. Following the machining process, the rings are hard anodized in elegant black for extended wear life.
These road chainrings are compatible with both 10 and 11 speed drivetrains, and are available in the three most common bolt circle diameters for Shimano, Campagnolo, and compact cranksets.
These chainrings are not supplied with fasteners; chainring nuts and bolts must be purchased separately. To function properly, Tune chainrings must be properly aligned with the chain drop pin positioned behind the crank arm.
Comment on Tune Aluminum Chainrings
