Tools
Detail From the same brilliant wheelbuilder that brought us the ELF and Orc hubs comes an invaluable yet unassuming little tool. This L-shaped bladed...
$18.002 options.View
The Alpine Scale is specifically designed to weigh bicycles, wheels, backpacks and any other outdoor sports equipment. The patented design enables...
$70.000 in stock.View
Specifications Accuracy+/- 1.0 gram Display Resolution1 gram FunctionsMetric, English; Zero, Tare Weighing Surface14 x 14 cm BatteriesAAA (2) ...
$55.002 in stock.View
This 15 mm pedal wrench, manufactured from durable Cr-Mo steel, is designed to fit any pedal with 15 mm wrench flats. This wrench's minimal 4mm width...
$10.000 in stock.View
This inexpensive yet durable 3/32" chain whip from Ice Toolz is designed for use with any multi-speed cassette, from 6 to 11 speed. Combined with the...
$9.000 in stock.View
This consumer-level chain tool from Ice Toolz is designed for use with 7, 8, 9, and 10 speed Shimano compatible chains, and uses a 1.5 link shelf to...
$12.001 in stock.View
This professional quality chain tool from Ice Toolz features a patented design on par with the best chain tools available. Compatibility includes all...
$25.002 options.View
Fastest, easiest tool to use on the market. Aligns, cleans, and faces the bottom bracket. Can be used on steel or aluminum shells (1.370"x24TPI...
$175.000 in stock.View
Fastest, easiest tool to use on the market. Aligns, cleans, and faces the bottom bracket. Can be used on steel or aluminum shells (36mmx24TPI...
Pro shop cable and spoke cutter, SIS SP durability rated, case hardened. Contains patented inner wire and outer casing conditioner. Patented.
$42.000 in stock.View
This stainless steel go/no-go chain checker operates in a simple, foolproof fashion. The side of the tool is etched with these simple instructions:...
$9.500 in stock.View
The Ice Toolz Chain Master is designed for rear chainstay, dropout, and derailleur protection when you travel. Additionally, this patented device...
$8.000 in stock.View
Professional tool for chainring bolt installation, Cr-V steel. No more cracking your knuckles during operation.
$5.000 in stock.View
This set of highly polished Chromium Vanadium combination wrenches includes 8 wrenches in millimeter increments from 8 to 15 mm. Each tool features a...
$50.001 in stock.View
Faster, safer, and more precise crown race installation tool. Unique patented centerline sleeve guide allows you to precisely align any model fork...
$70.001 in stock.View
Headset cup / BB cup press tool, up to 1-1/2”. For head tube length up to 260mm.
$120.000 in stock.View
Headset cup remover for cups sized 1", 1-1/8", and 1-1/4".
$20.000 in stock.View
Fastest, easiest tool to use, aligns and presses any headset for fool proof installation. Step bushing for any headset size, also 1 pc. BB Sets...
$100.000 in stock.View
These high quality internal nipple spoke wrenches are manufactured from SNCM steel with a high impact plastic handle. The 115 mm long extension will...
$8.003 options.View
These lateral spoke wrenches from Ice Toolz allow for easier building and truing of wheels with light gauge bladed spokes or stubborn, frozen...
$7.003 options.View
This high quality, CNC engineered bottom bracket tool is compatible with Shimano Octalink, ISIS, and many other inboard bearing bottom brackets. It...
This BB cup removal / installation tool is compatible with Shimano Hollowtech II, Campagnolo Ultra-Torque, and outboard bearing bottom brackets from...
$13.000 in stock.View
No home mechanic's toolbox would be complete without a saw guide, such as this model from Ice Toolz. Designed for use with all common bicycle tubing...
$38.000 in stock.View
This cassette tool, manufactured from Cr-V steel, is compatible with Shimano style lockrings, as well as lockrings for center lock disc brake rotors....
$7.000 in stock.View
Ice Toolz' spoke wrenches feature a standard, proven design with Cr-Mo construction and coated handles. They are available in two sizes: 0.127" to...
$5.002 options.View
Allows precise alignment of any star nut will work on 1” & 1-1/8” steerers. Perfect for high use shop environment.
$15.002 in stock.View
Complete set of frame and pedal taps (8-taps) with E-161 handle securely packaged in a professional carrying case.
Ice Toolz' Nylon/Fiberglass composite tire levers are strong, but not too strong, to allow easy tire removal without fear of scratching or otherwise...
$3.500 in stock.View
Every year, more components are being made with advanced lightweight materials that require precise installation. Know exactly when you have achieved...
$53.002 options.View
Specifications Valve compatibility Presta only Detail KCNC's pump head provides a great aftermarket upgrade option for the most common...
$40.000 in stock.View
Detail KMC's MissingLink chain master link tools are specifically designed for use with KMC chains, but they will work well with most other...
$15.002 options.View
Specifications Chain Compatibility8, 9, 10, 11 speed and single speed BatteryLR44 1.5V Body Materialhardened stainless steel Accuracy0.01mm (.0005...
$85.001 in stock.View
The Lezyne Carbon 10 multi-tool features the most commonly used bike related tools, held together with carbon side plates and titanium hardware. The...
$99.000 in stock.View
The Carbon 5 is the lightest bare bones multi-tool available, featuring carbon fiber side plates, and titanium hardware. It includes 3, 4, 5, and 6mm...
$80.000 in stock.View
Long leverage design ideal for downhill or wire bead tiresThin hook slips easily under tire beadHeat treated, CNC machined stainless steelBottle...
$30.002 in stock.View
The Lezyne Shock Drive is a beautifully crafted, highly functional precise inflation tool for your fork and rear-shock. The hose easily attaches to...
$45.000 in stock.View
The Lezyne Stainless 20 is the holy-grail of bicycle multi-tools. Short of riding with a portable work-bench, the Stainless 20 is your best bet. It...
The Lezyne V10 packs a lot of utility in to a relatively small form factor. Instead of using the traditional wrapping bit around an axle style most...
$36.000 in stock.View
The Lezyne V5 is so small, you can't afford not to carry it. It features a minimal set of bits, which are responsible for 90% of adjustments on your...
$17.500 in stock.View
You just spent a small fortune outfitting your bike with carbon components. Betting you can feel 5 newton meters just isn't good enough to ensure you...
Detail This bladed spoke holder from Belgian manufacturer Sapim helps prevent unwanted spoke twist by securely holding the spoke's blade within a...
The i2600 is a professional quality scale, accurate to the tenth of a gram and easy to operate. This scale is equipped with a commercial grade 26000...
$155.000 in stock.View
