Tires & Tubes
Handmade Tubulars with the strong racing heritage to back them up, Challenge is the current iteration of Clement, who were a mainstay in the Pro...
$89.00 $75.65Save: $13.35 off
2 options.View
The light tubular especially developed for time trial. Crono bites the road providing maximum grip and minimal rolling resistance at the same time....
$109.00 $92.65Save: $16.35 off
4 in stock.View
Designed in cooperation with cyclocross professional riders, Fango is the perfect for muddy conditions tire to your wheels. Width: 32mm Weight: 340gr...
$80.00 $64.00Save: $16.00 off
1 in stock.View
Specifications Weight~240 grams Size700c (622 mm) Width23 mm Casing240 TPI BeadKevlar, folding Pressure Range101-131 PSI (7-10 bar) Detail...
$40.00 $34.00Save: $6.00 off
3 options.View
Specifications Weight 60 grams (road), 85 grams (CX), 100 grams (MTB) Size 26" x 1.9 - 2.2" Presta Valve 48mm with removable core ...
$12.00 $8.40Save: $3.60 off
1 options.View
All purpose competition tire. Tread provides excellent grip on both wet and dry road conditions. 700c 22mm
$110.00-3 in stock.View
Dugast Strada Silk : All purpose pro-competition tubular. The silk provides better traction and extra comfort at higher tire pressures, resulting in...
$140.000 in stock.View
Specifications Weight, 39 mm2.1 grams Weight, 55 mm3.1 grams Detail These original replacement valve extenders from Enve are designed to fit their...
$8.002 options.View
Specifications Weight, 50 mm2.2 grams each Weight, 85 mm4.2 grams each Valve CompatibilityPresta Detail KCNC's lightweight valve extenders are a...
$12.007 options.View
Rox Ultralite rim strips are manufactured from lightweight puncture-resistant nylon with a super sticky adhesive backing. The lightest rim strip on...
$13.004 in stock.View
For some reason, up until now we had not thought to put lightweight tubes on our website. Due to repeated customer inquiries we decided to research...
$10.000 in stock.View
Specifications Weight75 grams Tire Compatibility700c x 19-23 Valve TypePresta, removeable Valve Length51 mm Detail To get the best ride quality and...
$15.0011 in stock.View
A high quality, lightweight tube that is equal to a latex tube in performance and has much better air retention. 42mm stem and we weigh them at 90g.
$7.0015 in stock.View
Aquaseal is a polyurethane sealant which helps to protect the cotton and silk sidewalls of Challenge and Dugast tubular tires. It keeps water from...
$7.009 in stock.View
Much like Aquaseal, Seam Grip is used on the cotton or silk sidewalls of Challenge and Dugast tubular tires. It keeps water out, and improves the...
$7.006 in stock.View
