Tires & Tubes
Challenge Criterium Tubular
Handmade Tubulars with the strong racing heritage to back them up, Challenge is the current iteration of Clement, who were a mainstay in the Pro...
$89.00  $75.65
Save: $13.35 off
2 options.View
Challenge Crono Tubular 22mm
The light tubular especially developed for time trial. Crono bites the road providing maximum grip and minimal rolling resistance at the same time....
$109.00  $92.65
Save: $16.35 off
4 in stock.View
Challenge Fango Open Clincher, 32mm
Designed in cooperation with cyclocross professional riders, Fango is the perfect for muddy conditions tire to your wheels. Width: 32mm Weight: 340gr...
$80.00  $64.00
Save: $16.00 off
1 in stock.View
Challenge Gara Open Clincher Tire
Specifications Weight~240 grams Size700c (622 mm) Width23 mm Casing240 TPI BeadKevlar, folding Pressure Range101-131 PSI (7-10 bar) Detail...
$40.00  $34.00
Save: $6.00 off
3 options.View
Challenge Latex Corsa Tube
Specifications Weight 60 grams (road), 85 grams (CX), 100 grams (MTB) Size 26" x 1.9 - 2.2" Presta Valve 48mm with removable core ...
$12.00  $8.40
Save: $3.60 off
1 options.View
Dugast Strada Cotton Tubular
All purpose competition tire. Tread provides excellent grip on both wet and dry road conditions. 700c 22mm
$110.00
-3 in stock.View
Dugast Strada Silk Tubular
Dugast Strada Silk : All purpose pro-competition tubular. The silk provides better traction and extra comfort at higher tire pressures, resulting in...
$140.00
0 in stock.View
Enve Valve Extender
Specifications Weight, 39 mm2.1 grams Weight, 55 mm3.1 grams Detail These original replacement valve extenders from Enve are designed to fit their...
$8.00
2 options.View
KCNC Valve Extenders
Specifications Weight, 50 mm2.2 grams each Weight, 85 mm4.2 grams each Valve CompatibilityPresta Detail KCNC's lightweight valve extenders are a...
$12.00
7 options.View
Rox Ultralite Rim Strip
Rox Ultralite rim strips are manufactured from lightweight puncture-resistant nylon with a super sticky adhesive backing. The lightest rim strip on...
$13.00
3 in stock.View
Vittoria EVO Lightweight Presta Tube 55g
For some reason, up until now we had not thought to put lightweight tubes on our website. Due to repeated customer inquiries we decided to research...
$10.00
0 in stock.View
Vittoria Latex Tube, 700c x 19-23
Specifications Weight75 grams Tire Compatibility700c x 19-23 Valve TypePresta, removeable Valve Length51 mm Detail To get the best ride quality and...
$15.00
5 in stock.View
Vittoria Ultralite tube 90g
A high quality, lightweight tube that is equal to a latex tube in performance and has much better air retention. 42mm stem and we weigh them at 90g.
$7.00
15 in stock.View
Aquaseal
Aquaseal is a polyurethane sealant which helps to protect the cotton and silk sidewalls of Challenge and Dugast tubular tires. It keeps water from...
$7.00
9 in stock.View
Seam Grip
Much like Aquaseal, Seam Grip is used on the cotton or silk sidewalls of Challenge and Dugast tubular tires. It keeps water out, and improves the...
$7.00
6 in stock.View
