THM Road Bottom Brackets
Sign Up For Our Newsletter
You're Signed Up!
Weight
BSA English 72g
Italian 72g
BB30 89g
PF30 90g
BB Right 90g
Shimano Press Fit 51g
SBI PF30, OSBB 99g
THM Road Bottom Brackets BB30 $160.00 In Stock
THM Road Bottom Brackets BB386 Evo $120.00 In Stock
THM Road Bottom Brackets BBRight $160.00 Notify Me When Available
THM Road Bottom Brackets BBRight, Direct Fit $120.00 In Stock
THM Road Bottom Brackets BSA English Threaded $100.00 Notify Me When Available
THM Road Bottom Brackets Italian $125.00  1 Remaining
THM Road Bottom Brackets PF30 $160.00 Notify Me When Available
THM Road Bottom Brackets SBI PF30, Carbon OSBB $160.00 Notify Me When Available
THM Road Bottom Brackets Shimano Press Fit (Road) $145.00 In Stock
THM Road Bottom Brackets Full Ceramic UpgradeBB30, PF30, BSA, BB $240.00 Notify Me When Available
THM Road Bottom Brackets Hybrid Ceramic UpgradeBB30, PF30, BSA, B $90.00 In Stock
THM Road Bottom Brackets Installation Tool $20.00 Notify Me When Available
THM Bottom Bracket Details
As a standard, THM cranks use a 30mm spindle. In order to satisfy an ever growing market of new bottom bracket standards, THM has created several BB’s to be used with their Clavicula, M3 cranks, and 68mm wide mountain bike cranks in the following bottom bracket shell sizes.
BSA English
Fits standard sized bottom bracket shells with English facing threads.
Italian
Fits standard sized bottom bracket shells with Italian facing threads.
BB30
Fits oversized BB30 frames.
PF BB30
Fits oversized BB30 frames, which are specifically Press Fit.
BB Right
Fits Cervelo’s BB Right bottom bracket standard.
Shimano PressFit
Fits Trek’s BB90 bottom bracket standard.THM is able to achieve this wide range of compatibility with their relatively wide 30mm spindle by externalizing their bearings, rather than a standard BB30 design which internalizes them. This additionally helps distribute, and thus reduce load on the spindle axle.
Specialized's (SBI) PF30 and OSBB standards are unique to Specialized bikes. In other words the PF30 on a Specialized is not the same PFC30 on another bike. If you have a PF30 equiped Specialized this bottom bracket will work on your frame. If you have an OSBB frame make sure youhave a carbon OSBB.
Comment on THM Road Bottom Brackets
