THM M3 Modular Road Crank
Sign Up For Our Newsletter
You're Signed Up!
Spindle Diameter 30 mm
Bottom Bracket Options* BSA, ITA, BB86, BB30, PF30,
BB386 Evo,
BBRight Press Fit,
BBRight Direct Fit,
Crankarm Options 170, 172.5, 175 mm
Spider BCD Options 110 compact,
130 standard
Finish Options gloss, matte
Q Factor 147 mm
Rider Weight Limit 110 kg (243 lbs)
Weight
Crank Arms Only 354 grams
Compact Spider 46 grams
Standard Spider 46 grams
Bottom Bracket Weights
THM M3 Modular Road Crank 170 Gloss Arms $949.00 Notify Me When Available
THM M3 Modular Road Crank 170 Matte Arms $949.00 Notify Me When Available
THM M3 Modular Road Crank 172.5 Gloss Arms $949.00 Notify Me When Available
THM M3 Modular Road Crank 172.5 Matte Arms $949.00 Notify Me When Available
THM M3 Modular Road Crank 175 Gloss Arms $949.00 Notify Me When Available
THM M3 Modular Road Crank 175 Matte Arms $949.00 Notify Me When Available
THM M3 Modular Road Crank Spider, Compact 110 $149.00 Notify Me When Available
THM M3 Modular Road Crank Spider, Standard 130 $149.00  1 Remaining
THM M3 Modular Road Crank BB30 $160.00 In Stock
THM M3 Modular Road Crank BB386 Evo $120.00 In Stock
THM M3 Modular Road Crank BBRight $160.00 Notify Me When Available
THM M3 Modular Road Crank BBRight, Direct Fit $120.00 In Stock
THM M3 Modular Road Crank BSA English Threaded $100.00 Notify Me When Available
THM M3 Modular Road Crank Italian $125.00  1 Remaining
THM M3 Modular Road Crank PF30 $160.00 Notify Me When Available
THM M3 Modular Road Crank SBI PF30, Carbon OSBB $160.00 Notify Me When Available
THM M3 Modular Road Crank Shimano Press Fit (Road) $145.00 In Stock
THM M3 Modular Road Crank Full Ceramic UpgradeBB30, PF30, BSA, BB $240.00 Notify Me When Available
THM M3 Modular Road Crank Hybrid Ceramic UpgradeBB30, PF30, BSA, B $90.00 In Stock
THM M3 Modular Road Crank Installation Tool $20.00 Notify Me When Available
Details
THM's M3 crank, makes several improvements over their long-standing Clavicula design with little compromise in weight and greatly increased durability with several interchangeable bottom bracket and chainring spider options. While the M3 retains a similar full carbon arm structure as its predecessor, the oversize spindle has been redesigned in aluminum for greater reliability and overall strength. In this redesign, THM made another marked improvement; the chainring spider is now completely interchangeable to allow cross compatibility between standard and compact road chainrings, and the spindle is fitted with SRM-compatible splines, allowing discerning cyclists the option of using a crank-based power meter with very little weight penalty.
Please note that Clavicula cranks are designed for extended, yet ultimately limited use. These cranks should be retired or returned to THM for inspection after 100,000 km (62,000 mi) or after 10 years of use.
Ordering
THM M3 is sold as a modular crankset. Please make sure to order all necessary parts. Choose crank arms by length and finish. Choose spider by Compact (110BCD) or Standard (130BCD). Please note that spider includes spider mounting bolts. Choose bottom bracket fit. Then just add chainring bolts and chainrings for a complete crankset.
Installation/Assembly
Detailed installation instructions are included. A torque wrench with 4 and 5 mm hex bits is required for proper installation of the spider and crank arms. If you are ordering a threaded bottom bracket a THM installation tool is necessary.
Comment on THM M3 Modular Road Crank
