THM M3 Modular Crank
THM M3 Modular Crank 170 Gloss Arms $850.00  1 Remaining
THM M3 Modular Crank 170 Matte Arms $850.00 Notify Me When Available
THM M3 Modular Crank 172.5 Gloss Arms $850.00 In Stock
THM M3 Modular Crank 172.5 Matte Arms $850.00 Notify Me When Available
THM M3 Modular Crank 175 Gloss Arms $850.00 Notify Me When Available
THM M3 Modular Crank 175 Matte Arms $850.00 Notify Me When Available
THM M3 Modular Crank Spider, Compact 110 $140.00 Notify Me When Available
THM M3 Modular Crank Spider, Standard 130 $140.00 In Stock
THM M3 Modular Crank THM Bottom Bracket - BB30 $160.00 In Stock
THM M3 Modular Crank THM Bottom Bracket - BBRight $160.00 Notify Me When Available
THM M3 Modular Crank THM Bottom Bracket - BBRight, Direct Fit $120.00 Notify Me When Available
THM M3 Modular Crank THM Bottom Bracket - BSA English Threaded $100.00 Notify Me When Available
THM M3 Modular Crank THM Bottom Bracket - Italian $125.00 Notify Me When Available
THM M3 Modular Crank THM Bottom Bracket - PF30 $160.00  2 Remaining
THM M3 Modular Crank THM Bottom Bracket - Shimano Press Fit (Road) $120.00 Notify Me When Available
THM M3 Modular Crank Full Ceramic Upgrade - BB30, PF30, BSA, BB Right $240.00 Notify Me When Available
THM M3 Modular Crank Hybrid Ceramic Upgrade - BB30, PF30, BSA, BB Right $90.00 In Stock
THM M3 Modular Crank Installation Tool $20.00 In Stock
Weight, crank arms only337 grams
Weight, compact spider46 grams
Weight, English BB Cups73 grams
Spindle Diameter30 mm
Bottom Bracket Options*BSA, ITA, BB86,
BB30, PF30, BBRight
Crankarm Options170, 172.5, 175 mm
Spider BCD Options110 compact, 130 standard
Finish Optionsgloss, matte
Q Factor147 mm
Rider Weight Limit110 kg (243 lbs)
THM's newest crankset, the M3, makes several improvements over their long-standing Clavicula design with little compromise in weight and greatly increased durability with several interchangeable bottom bracket and chainring spider options. While the M3 retains a similar full carbon arm structure as its predecessor, the oversize spindle has been redesigned in aluminum for greater reliability and overall strength. In this redesign, THM made another marked improvement; the chainring spider is now completely interchangeable to allow cross compatibility between standard and compact road chainrings, and the spindle is fitted with SRM-compatible splines, allowing discerning cyclists the option of using a power meter with very little weight penalty.
Please note that Clavicula cranks are designed for extended, yet ultimately limited use. These cranks should be retired or returned to THM for inspection after 100,000 km (62,000 mi) or after 10 years of use.
Ordering
THM M3 is sold as a modular crankset. Please make sure to order all necessary parts. Choose crank arms by length and finish. Choose spider by Compact (110BCD) or Standard (130BCD). Please note that spider includes spider mounting bolts. Choose bottom bracket fit. Then just add chainring bolts and chainrings for a complete crankset.
Installation/Assembly
Detailed installation instructions are included. All threaded bottom brackets include the THM installation tool. A torque wrench with 4 and 5 mm hex bits is required for proper installation of the spider and crank arms.
Comment on THM M3 Modular Crank
