THM
THM Bottom Bracket
As a standard, THM cranks use a 30mm spindle. In order to satisfy an ever growing market of new bottom bracket standards, THM has created several...
10 options.View
THM Bottom Bracket Installation Tool
In order to install or remove threaded (not press-fit) type THM bottom brackets, you will need this tool to fit the cup splines. Note that THM’s BB...
1 options.View
THM Clavicula Compact Crankset
*Please contact us to special order these lengths. Detail THM's renowned full carbon Clavicula crankset features a revolutionary design which makes...
15 options.View
THM Clavicula DP Mountain Crankset
*Please contact us to special order these lengths. Detail The Clavicula DP is a lighter, faster version of THM's mountain triple crankset, and at a...
8 options.View
THM Clavicula DP68 Mountain Crankset
*Please contact us to special order these lengths. Detail This DP68 version of the Clavicula mountain double crankset is THM's absolute lightest...
8 options.View
THM Clavicula Mountain Crankset
Detail THM's mountain triple Clavicula crankset is the result of a long period of development and uncountable test runs; it is quite possibly the...
8 options.View
THM Clavicula Road Crankset
15 options.View
THM Fibula Carbon Road Brake Set
THM'sFibula brake set exquisitely unites the seemingly impossible; insane light weight and optimized braking power.Provided is a level of braking...
2 options.View
THM M3 Modular Crank
Detail THM's newest crankset, the M3, makes several improvements over their long-standing Clavicula design with little compromise in weight and...
18 options.View
THM Mountain Bottom Brackets
Detail These BB30 adapter bearing cups are designed for use with THM's line of Clavicula cranksets. Compatible bottom bracket shells will be 68 mm...
5 options.View
THM Scapula CT Carbon Fork
As a small scale carbon manufacturer, German company THM-Carbones releases new products on a fairly infrequent basis. Their careful, thorough design...
2 options.View
THM Scapula F Aero Carbon Fork
While a handful of manufacturers have successfullymated an aerodynamic fork and front brake, none has so elegantly accomplished anything similar to...
5 options.View
THM Scapula SP Carbon Fork
Detail SP is an acronym for the Latin "sine pondere", which translates to "without weight." At only 260 grams, THM's Scapula SP sets the limit of...
0 in stock.View
THM Spina Scapula Fork Cover
Detail Spina Scapulae is Latin for shoulder blade, or simply, scapula. THM's Spina covers the "shoulders" of their Scapula-series fork crowns to...
0 in stock.View
THM Ceramic Bottom Bracket Upgrade
Our THM road and mountain bike kits use the same HSC hybrid ceramic bearings that we've been working with foryears now and highly recommend. HSC's...
2 options.View
THM Brake Pad Holders
Detail At a mere ten grams per pair, THM's brake pad holders are the lightest standard pad holders in the world. They are compatible with most modern...
-1 in stock.View
