THM Fibula Carbon Road Brake Set
THM Fibula Carbon Road Brake Set Gloss$1,250.00 Notify Me When Available
THM Fibula Carbon Road Brake Set Matte$1,250.00 Notify Me When Available
Weight per Pair w/ Hardware138 grams
Pad Reach39-49 mm
Front Brake Actuation Ratio1:1.75
Rear Brake Actuation Ratio1:1.50
Pad CompatibilityShimano
Rider Weight Limit120 kg (265 lbs)
THM's Fibula brake set exquisitely unites the seemingly impossible; insane light weight and optimized braking power. Provided is a level of braking performance on par with Shimano's benchmark-setting Dura Ace brakes, but with an intelligent front- and rear-specific design. Unlike most manufacturers, THM chose to individually optimize the braking power of their brake set. The front brake, which carries the bulk of the load in braking decelerations, is designed with the highest actuation ratio for all out stopping power. Conversely, the rear brake is designed with a lower ratio to prevent wheel lock up under "panic" stops, increasing rider safety.
Mounting hardware, compatible with most manufacturers' frames and forks, is included, as is a THM specific brake block centering tool.
THM products are designed and manufactured in Germany with precision and attention to detail.
Ordering
Fibula brakes are sold with pad holders, but without brake pads. We highly recommend pairing these brakes with high quality Swiss Stop Flash Pro brake pads.
A highly detailed instruction manual is included to ensure proper and safe assembly.
Comment on THM Fibula Carbon Road Brake Set
