| Weight | 420 grams |
| BB Compatibility | 68 mm, English (1.37 x 24 tpi) |
| Chainline | 43.5 mm |
| Available Lengths | 170*, 172.5, 175* mm |
Bolt Circle Diameter
| 110 mm
| Q Factor | 152 mm |
| Crank Inner Width | 118 mm |
| Rider Weight Limit | 105 kg (230 lbs) |
*Please
contact us to special order these lengths.
THM's renowned full carbon Clavicula crankset features a revolutionary design which makes no compromises in weight, performance, or aesthetics. These cranks were cooperatively created with Cologne, a German-based design specialist.
New production methods, never before used for bicycle cranksets, allow for a giant leap in total stiffness. The crank's stiffness-to-weight ratio set a new standard which rival manufacturers have yet to match. In-house lab testing of various high end cranks show the superior performance of the Clavicula crank system.
These are compact road cranks, designed with a compact 110 mm bolt circle diameter, and compatible with 68 mm wide bottom bracket shells. The cartridge bearing bottom bracket attaches outside of the frame using standard BSA threads. This design allows the use of larger diameter bearings and a wider bearing placement. In combination with the 30 mm diameter spindle, these modifications make for a very stiff drivetrain. Optional bearing cups for Italian threaded and BB30 bottom brackets are available upon request.
Extensive testing of this ground-breaking invention was THM's top priority. Various long term and stress tests have been undertaken, because as a pure-bred racing component the Clavicula must be able to continually withstand the highest loads; be it in hard sprints or during the toughest classics.
Please note that chainrings are NOT included with this crankset.
A proprietary bottom bracket cup tool is included with each Clavicula crankset. Along with this tool, all that is required for installation is a 4mm hex wrench and a torque wrench. Detailed installation instructions are included.
