TA Syrius Compact Chainrings (110 BCD)
TA Syrius Compact Chainrings (110 BCD) Black, 34 Tooth$65.00  2 Remaining
TA Syrius Compact Chainrings (110 BCD) Black, 36 Tooth$65.00  1 Remaining
TA Syrius Compact Chainrings (110 BCD) Black, 50 Tooth$100.00 In Stock
Weight 34t, 31g
36t, 35g
50t, 85g
Sizes 34T, 36T, 50T
Colors Black
Details
TA Specialties manufactures high quality aftermarket aluminum chainrings in a wide variety of sizes and colors. 7075 T6 aluminum is the material of choice for an excellent balance between strength, weight, and stiffness - all important factors in chainring design. The machining process for these chainrings saves additional weight, while adding elements of style and beauty not normally seen on a chainring. The finish work is not skimped on, with a high quality glossy black anodized finish, along with tastefully executed laser-cut logos. The outer chainring design features machined shift ramps and bonded steel pins for quick and precise shifts.
Syrius series chainrings are manufactured with the compact road 110mm bolt circle diameter. These rings are compatible with all compact cranksets, with the exception of Campagnolo and Fulcrum.
Comment on TA Syrius Compact Chainrings (110 BCD)
