TA Squale Chainrings (130 BCD)
TA Squale Chainrings (130 BCD) Silver 52T$160.00  1 Remaining
TA Squale Chainrings (130 BCD) Silver 53T$160.00  1 Remaining
Weight 90g
Sizes 52T, 53T
Colors Polished Silver
Details
TA Specialties manufactures high quality aftermarket aluminum chainrings in a wide variety of sizes and colors. 7075 T6 aluminum is the material of choice for an excellent balance between strength, weight, and stiffness - all important factors in chainring design. The Squale chainring is not so aggressively machined as other rings with the TA catalog. Rather, material is intentionally left on the outer surface to improve stiffness and aerodynamics. Additionally, TA uses an integrated chainring nut design (called IFS) to further increase aerodynamics and aesthetic appeal. The finish work is not skimped on, with a high quality polished silver finish, along with tastefully executed laser-cut logos. The Squale's design also features machined shift ramps and bonded steel pins for quick and precise shifts.
Squale series chainrings are manufactured with the Shimano road 130mm bolt circle diameter. These rings are compatible with most standard road cranksets. Chainring bolts and necessary mounting hardware are included.
Comment on TA Squale Chainrings (130 BCD)
