TA Nerius 11 Chainrings
TA Nerius 11 Chainrings 34 Tooth$68.00  2 Remaining
TA Nerius 11 Chainrings 36 Tooth$68.00  2 Remaining
TA Nerius 11 Chainrings 50 Tooth$114.00  2 Remaining
Weight, 34 Tooth30 grams
Weight, 36 Tooth39 grams
Weight, 50 Tooth75 grams
BCDCampagnolo compact 110
Material7076 T6 aluminum
Finshmatte grey
Compatible Cranksetscompact Campagnolo and Fulcrum
TA Specialites' Nerius 11 chainrings are designed as lightweight aftermarket replacements for Campagnolo and Fulcrum compact cranksets. 7075 T6 aluminum is the material of choice for an excellent balance between strength, weight, and stiffness - all important factors in chainring design. The outer chainring design features machined shift ramps and bonded steel pins for quick and precise shifts. Nerius 11 chainrings are fully 11 speed compatible, and will only fit Campagnolo-standard 110 BCD cranksets. These chainrings are finished in an attractive anthracite grey anodization with tastefully executed laser cut logos.
TA chainrings are designed and manufactured in France.
Comment on TA Nerius 11 Chainrings
