TA Horus 11 Chainrings
TA Horus 11 Chainrings 39 Tooth$72.00  2 Remaining
TA Horus 11 Chainrings 53 Tooth$116.00  2 Remaining
Weight, 39 Tooth33 grams
Weight, 53 Tooth82 grams
BCDCampagnolo 135
Material7076 T6 aluminum
Finshmatte grey
Compatible CranksetsCampagnolo, Fulcrum
TA Specialites' Horus 11 chainrings are designed as lightweight aftermarket replacements for Campagnolo and Fulcrum cranksets. 7075 T6 aluminum is the material of choice for an excellent balance between strength, weight, and stiffness - all important factors in chainring design. The outer chainring design features machined shift ramps and bonded steel pins for quick and precise shifts. Horus 11 chainrings are fully 11 speed compatible, and will only fit Campagnolo-standard 135 BCD cranksets. These chainrings are finished in an attractive anthracite grey anodization with tastefully executed laser cut logos.
TA chainrings are designed and manufactured in France.
Comment on TA Horus 11 Chainrings
