TA Hegoa Chainrings (130 BCD)
TA Hegoa Chainrings (130 BCD) Black, 38 Tooth$70.00 Notify Me When Available
TA Hegoa Chainrings (130 BCD) Black, 39 Tooth$70.00  2 Remaining
TA Hegoa Chainrings (130 BCD) Black, 42 Tooth$70.00  1 Remaining
TA Hegoa Chainrings (130 BCD) Black, 50 Tooth$105.00 Notify Me When Available
TA Hegoa Chainrings (130 BCD) Black, 52 Tooth$105.00  1 Remaining
TA Hegoa Chainrings (130 BCD) Black, 53 Tooth$105.00  2 Remaining
Closeout - Colored Chainrings
25% Discount
Weight, 38 Tooth32 grams
Weight, 39 Tooth32 grams
Weight, 42 Tooth35 grams
Weight, 50 Tooth78 grams
Weight, 52 Tooth83 grams
Weight, 53 Tooth89 grams
Material7075 T6 aluminum
BCD130 mm
Compatibility9, 10 speed
TA Specialties manufactures high quality aftermarket aluminum chainrings in a wide variety of sizes and colors. 7075 T6 aluminum is the material of choice for an excellent balance between strength, weight, and stiffness - all important factors in chainring design. The machining process for these chainrings saves additional weight, while adding elements of style and beauty not normally seen on chainrings. The finish work is not skimped on, with a high quality glossy anodized finish, along with tastefully executed laser-cut logos. The outer chainring design features machined shift ramps and bonded steel pins for quick and precise shifts.
Hegoa series chainrings are manufactured with the Shimano road 130mm bolt circle diameter. These rings are compatible with most standard road cranksets.
Comment on TA Hegoa Chainrings (130 BCD)
