Swiss Stop Shimano Brake Pads
Sign Up For Our Newsletter
You're Signed Up!
Compatible Pad Holders Shimano, Sram, eeBrakes, etc.
Weights
Black Prince 34 grams per set
BXP 23 grams per set
Original Black 26 grams per set
Available Compounds Original Black, BXP, Black Prince
Swiss Stop Shimano Brake Pads Black Prince $45.00 Notify Me When Available
Swiss Stop Shimano Brake Pads BXP $30.00 Notify Me When Available
Swiss Stop Shimano Brake Pads Original Black $24.00 Notify Me When Available
Swiss Stop Flash Pro Details
Swiss Stop is perhaps the most technologically advanced brake pad manufacturer in the bicycle industry. From development, to testing and production, no expense is spared to produce a superior product. Swiss Stop relies on its engineers, test riders, and industry partners for feedback and constant redesign and optimization of compound formulas. Their obsessive attention to detail ensures that the end product is the absolute best available.
Original Black
An ideal pad for everyday use, Swiss Stop's Black compound works well on all aluminum rims and is well suited for softer alloys, including magnesium.
BXP
The BXP brake compound is designed for high performance all around use on alloy rims. Wet or dry the BXP is designed to perform up to and beyond the expectations of any other brake pad on the market.
Black Prince
We've replaced Swiss Stop's Yellow king with the new Black Prince compound. The Black Prince provides better modulation and cooler operating temperatures making it the best carbon brake pad compound we've used to date.
Do not loosen or remove the brake pad holder. Remove the small fixing screw and slide out the old pad. Clean the brake pad holder, insert the new brake pad, and install the supplied new fixing screws. Check pad alignment for proper contact of the rim's braking surface. When installing new brake pads, be sure to clean rim and all brake surfaces of any foreign particles. Please consult your rim's manufacturer for proper cleaning methods.
Links
