Swiss Stop Flash Pro Brake Pads
Swiss Stop Flash Pro Brake Pads GHP II$30.00 In Stock
Swiss Stop Flash Pro Brake Pads Original Black$24.00 In Stock
Swiss Stop Flash Pro Brake Pads Yellow King$50.00 Notify Me When Available
Weight, Yellow King32 grams per set
Weight, GHP II22 grams per set
Weight, Original Black26 grams per set
Compatible Pad HoldersShimano, Sram, KCNC, etc.
Available CompoundsOriginal Black, GHP II, Yellow King
Swiss Stop is perhaps the most technologically advanced brake pad manufacturer in the bicycle industry. From development, to testing and production, no expense is spared to produce a superior product. Swiss Stop relies on its engineers, test riders, and industry partners for feedback and constant redesign and optimization of compound formulas. Their obsessive attention to detail ensures that the end product is the absolute best available.
Original Black
An ideal pad for everyday use, Swiss Stop's Black compound works well on all aluminum rims and is well suited for softer alloys, including magnesium.
GHP II
The Green High Performance pads feature an all weather compound designed for aluminum rims. These pads are designed for sport riders and racers, with great braking power with smooth modulation.
Yellow KingSwiss Stop's Yellow King compound has set the industry standard for high performance, carbon-compatible brake pads. These pads feature excellent stopping power in both wet and dry conditions, with superior modulation and low pad wear rates.
Do not loosen or remove the brake pad holder. Remove the small fixing screw and slide out the old pad. Clean the brake pad holder, insert the new brake pad, and install the supplied new fixing screws. Check pad alignment for proper contact of the rim's braking surface. When installing new brake pads, be sure to clean rim and all brake surfaces of any foreign particles. Please consult your rim's manufacturer for proper cleaning methods.
Links
To read more about Swiss Stop's development and production processes, check out theirtech center.
Comment on Swiss Stop Flash Pro Brake Pads
