Stems
Enve Carbon Stem
Specifications Weight, 75 mm110 grams Weight, 90 mm115 grams Weight, 100 mm120 grams Weight, 110 mm125 grams Weight, 120 mm130 grams Weight, 130...
$265.00
7 options.View
Extralite Ultrastem OC Mountain Stem (31.8)
Specifications Weight 100mm 83 grams Lengths 90mm, 100mm, 110mm Detail Extralite's New MTB OC features Hyper accurate dimensional engineering...
$230.00
3 options.View
Extralite Oversized OC Road Stem (31.8mm)
Specifications Weight 100mm 83 grams Lengths 90mm, 100mm, 110mm Angle +/-8 degrees Detail Extralite's New Roadstem OC features Hyper...
$230.00
4 options.View
Extralite UL3 MTB Stem (25.4mm)
Specifications Weight 100mm 82 grams Lengths 90mm, 100mm, 110mm Angle +/-4 degrees Detail Extralite's New Ultrastem UL3 features Hyper...
$230.00
3 options.View
Extralite UL3 Road Stem (26.0mm)
Specifications Weight 110mm 87 grams Lengths 90mm, 100mm, 110mm Angle +/-8 degrees Clamp Diameter 26.0 mm Detail Extralite's New Roadstem...
$230.00
3 options.View
Far and Near S1 Stem
Specifications Weight, 80 mm 122 grams Weight, 90 mm 127 grams Weight, 100 mm 136 grams Weight, 110 mm 144 grams Weight, 120 mm 155...
$85.00
5 options.View
Far and Near S2 Stem, White
Specifications Weight, 80 mm 110 grams Weight, 90 mm 116 grams Weight, 100 mm 124 grams Weight, 110 mm 135 grams Weight, 120 mm 146 grams ...
$90.00
5 options.View
KCNC Arrow Stem
Specifications Weight, 100 mm135 grams Weight, 110 mm140 grams Weight, 120 mm142 grams Weight, 130 mm145 grams Material7050 aluminum Available...
$90.00
10 options.View
KCNC Fly Ride Road Stem (26.0 mm)
Specifications Weight 124 grams Lengths 70mm, 80mm, 90mm, 100mm, 110mm, 120mm Angle +/-5 degrees Clamp Diameter 26.0 mm Material CNC'd...
$45.00
6 options.View
KCNC Fly Ride Stem (31.8mm)
Specifications Weight 124 grams Lengths 50mm, 60mm, 70mm, 80mm, 90mm, 100mm, 110mm, 120mm Angle +/-5 degrees Clamp Diameter 31.8 mm ...
$45.00
9 options.View
KCNC Team Issue Stem (31.8mm)
Specifications Weight 100mm 103 grams Lengths 80mm, 90mm, 100mm, 110mm, 120mm Angle +/-5 degrees Clamp Diameter 31.8 mm Stack Height 38 mm...
$90.00
5 options.View
KCNC Ti Pro Mountain Stem (25.4mm)
Specifications Weight 110mm 113 grams Lengths 80mm, 90mm, 100mm, 110mm Angle +/-5 degrees Clamp Diameter 25.4 mm Steerer Diameter 28.6 mm ...
$90.00
4 options.View
KCNC Ti Pro Road Stem (26.0mm)
Specifications Weight 110mm 113 grams Lengths 80mm, 90mm, 100mm, 110mm Angle +/-5 degrees Clamp Diameter 26.0 mm Steerer Diameter 28.6 mm ...
$90.00
5 options.View
New Ultimate Stem, Black (31.8mm)
Specifications Weight 110mm 107 grams Lengths 80mm, 90mm, 100mm, 110mm, 120mm, 130mm Angle +/-7 degrees Clamp Diameter 31.8 mm Material...
$100.00
6 options.View
New Ultimate Stem, White
Specifications Weight 80mm 107 grams Weight 100mm 117 grams Lengths 80mm, 90mm, 100mm, 110mm, 120mm, 130mm Torque Specs 5Nm on steerer tube...
$115.00
6 options.View
Tune Geiles Teil 4.0 Stem
Specifications Weight, 95 mm105 grams Weight, 110 mm120 grams Rise+/- 8 degree Stem Material7075 aluminum Bolt Material6/4 titanium Handlebar...
$225.00
4 options.View
Tune 25.4 Mountain Stem
Specifications Weights, 110mm128 grams Angle8 degree Diameters25.4 Lengths95mm, 110mm ColorsOrange, Black, Red Detail The 'Geiles Teil' stem from...
$168.00  $126.00
Save: $42.00 off
3 options.View
Tune 26.0 Road Stem
Specifications Weights, 110mm129 grams Angle8 degree Diameters26.0 Lengths60mm, 85mm, 95mm, 110mm ColorsPink, Orange, Black, Blue, Red Detail The...
$168.00  $126.00
Save: $42.00 off
7 options.View
Tune 31.8 Road / Mountain Stem
Specifications Weights, 85mm128 grams Angle8 degrees Diameters31.8 Lengths85mm, 95mm, 105mm, 115mm ColorsPink, Orange, Black, Blue, Red, Purple,...
$168.00  $126.00
Save: $42.00 off
10 options.View
