Stan's NoTubes ZTR Crest Rim 26
Stan's NoTubes ZTR Crest Rim 26 Black, 28 Hole $88.00 In Stock
Stan's NoTubes ZTR Crest Rim 26 Black, 32 Hole $88.00 In Stock
Weight340 grams
Width24.4 mm
Depth16.0 mm
Available Drillings28, 32 hole
Tire Compatibility26 (ISO 559) clincher and tubeless ready
Usecross country; disc brake only
ERD541 mm
The Stan's No Tubes ZTR Crest rim design blends the best aspects of the superlight ZTR Race and the more durable ZTR 355, allowing for superior strength-to-weight ratios in an accessible, affordable package. The Crest's carefully engineered cross section features an internal arch for strength, a wide profile, and Stan's patented Bead Socket Technology. Stan's BST system reduces the height of rim sidewalls, which saves weight, allows easier tire installation, and provides a secure seat for tubeless tire beads.
To convert a Stan's Crest rim to tubeless, a Stan's 35 mm Valve Stem and 25 mm tape are required. Stan's instructions for this conversion are located here.
Assembly
We recommend that wheels built with Stan's No Tubes rims be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in hub and spoke selections. Please contact us directly or submit a custom wheel build request here.
Comment on Stan's NoTubes ZTR Crest Rim 26
