Stan's NoTubes Rim Tape
Stan's NoTubes Rim Tape 12 mm Universal Kit Tape$6.00 In Stock
Stan's NoTubes Rim Tape 21 mm Tape$11.25 In Stock
Stan's NoTubes Rim Tape 25 mm Tape$13.50 Notify Me When Available
Weight, 12 mm3 grams per rim
Weight, 21 mm5 grams per rim
Weight, 25 mm7 grams per rim
Length per Roll10 yards
Stan's yellow tape is designed to be used as a high strength, lightweight, and airtight rim strip. When used in conjunction with a Stan's Valve Stem, this tape completely seals the tire bed of any Stan's ZTR rim, allowing for the use of a tubeless tire. Stan's Tape is also an excellent option for standard tire and tube setups.
Each 10 yard roll will tape up to five 26" rims, four 29" rims, or two 700c road rims. Due to the higher tire pressures required for road tires, two layers of tape must be used.
Ordering
21 mm width tape fits:
ZTR Olympic
ZTR 355
ZTR Alpine
ZTR Crest
ZTR Alpha 340
Most road clincher rims
25mm width tape fits:
ZTR 355 (26", 650b, 29")
ZTR Crest
ZTR Arch
ZTR Flow
12 mm tape is designed only as a non-tubeless rim strip for any standard clincher rim.
To aid adhesion, it is recommended that the rim's tire bed be scuffed with a scotch brite pad and cleaned with a residue-free solvent prior to application. When taping the rim, pull hard on the tape with a slight side-to-side motion to allow it to stretch and conform to the rim's cavity.
Comment on Stan's NoTubes Rim Tape
