Stan's No Tubes ZTR Crest Rim 650B
Stan's No Tubes ZTR Crest Rim 650B 32 Hole$88.00  1 Remaining
Weight360 grams
Width24.4 mm
Depth16.0 mm
Available Drillings32 hole
Tire Compatibility650b (ISO 584) clincher and tubeless ready
ERD565 mm
The Stan's No Tubes ZTR Crest 650b rim succeeds their 355 650b rim in a stiffer, lighter, and stronger package. With the growing popularity of this relatively new tire size, the Crest 650b is one of the few, and arguably the best rim option on the market. The Crest's carefully engineered cross section features an internal arch for strength, a wide profile, and Stan's patented Bead Socket Technology. Stan's BST system reduces the height of rim sidewalls, which saves weight, allows easier tire installation, and provides a secure seat for tubeless tire beads.
To convert a Stan's Crest rim to tubeless, a Stan's Olympic Valve Stem and 25 mm tape are required. Stan's instructions for this conversion are located here.
Assembly
We recommend that wheels built with Stan's No Tubes rims be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in hub and spoke selections. Please contact us directly or submit a custom wheel build request here.
Comment on Stan's No Tubes ZTR Crest Rim 650B
