Stan's No Tubes
Specifications Weight360 gramsWidth24.4 mmDepth16.0 mmAvailable Drillings32 holeTire Compatibility650b (ISO 584) clincher and tubeless readyERD565 mm...
$88.001 options.View
Specifications Weight25 grams per fluid ounce Detail Stan's Sealant is the foundation of their tubeless conversion business, and arguably the best...
$3.002 options.View
Specifications Weight, 12 mm3 grams per rimWeight, 21 mm5 grams per rimWeight, 25 mm7 grams per rimLength per Roll10 yards Detail Stan's yellow tape...
$6.003 options.View
Specifications Weight~355 gramsWidth21 mmDepth22 mmAvailable Drillings20, 24, 28, 32 holeERD591 mm Detail Exceedingly smooth, extraordinarily fast...
$120.005 options.View
Specifications Weight330 gramsWidth23.0 mmDepth17.4 mmAvailable Drillings28, 32 holeTire Compatibility26" (ISO 559) clincher and tubeless...
$88.002 options.View
Specifications Weight340 gramsWidth24.4 mmDepth16.0 mmAvailable Drillings28, 32 holeTire Compatibility26" (ISO 559) clincher and tubeless...
Specifications Weight380 gramsWidth24.4 mmDepth16.0 mmAvailable Drillings32 holeTire Compatibility29" (ISO 622) clincher and tubeless readyUsecross...
Specifications Weight, 35 mm6.5 gramsWeight, 44 mm7.5 grams Detail Stan's No Tubes valve stems are designed for tubeless conversion of their ZTR rim...
$8.002 options.View
