Spokes & Nipples
Specifications Weight4.4 - 4.6 grams each Materialcold forged stainless steel Blade Dimensions2.3 x 0.9 mm Thread2.2 x 56 tpi (2.0mm, 14g) Detail...
$3.0035 options.View
$2.8035 options.View
Specifications Weight4.8 - 5.0 grams each Materialcold forged stainless steel Blade Dimensions2.3 x 1.3 mm Thread2.2 x 56 tpi (2.0mm, 14g) Detail...
$5.0031 options.View
Specifications Weight4.6 - 5.2 grams each Materialcold forged stainless steel Diameter2.0 - 1.5 - 2.0 mm Thread2.2 x 56 tpi (2.0 mm, 14g) Detail...
$1.7536 options.View
$1.5036 options.View
Specifications Weight5.9 - 6.5 grams each Materialcold forged stainless steel Diameter2.0 - 1.8 - 2.0 mm Thread2.2 x 56 tpi (2.0 mm, 14g) Detail...
$1.5038 options.View
$1.2538 options.View
Specifications Weight.38 grams each Length9.4 mm Material7075 aluminum Tool Fitting3/16" hex Compatible Thread2.2 mm x 56 tpi (2.0 mm spokes) ...
$1.0029 in stock.View
Specifications Weight0.38 grams each Length14 mm Material7075 aluminum Compatible Thread2.2 mm x 56 tpi (2.0 mm spokes) Detail Sapim's series of...
$0.457 options.View
Please note that our current stock of red aluminum nipples does not have Sapim's self-locking feature. Specifications Weight0.38 grams each...
$0.506 options.View
Specifications Weight.05 grams Materialbrass Inner Diameter2.55 mm Outer Diameter4.80 mm Thickness.5 mm Detail Sapim's spoke washers are designed...
$0.12465 in stock.View
