Speed Evolution Aluminum Presta Valve
Sign Up For Our Newsletter
You're Signed Up!
Weight8.2 grams per pair
Material6065 Aluminum
Speed Evolution Aluminum Presta Valve Black $20.00 In Stock
Speed Evolution Aluminum Presta Valve Blue $20.00 In Stock
Speed Evolution Aluminum Presta Valve Gold $20.00 In Stock
Speed Evolution Aluminum Presta Valve Green $20.00 In Stock
Speed Evolution Aluminum Presta Valve Pink $20.00 In Stock
Speed Evolution Aluminum Presta Valve Red $20.00 In Stock
Details
Speed Evolution's tubeless aluminum presta valve features a patent pending larger recessed locking O-ring, a larger internal diameter to provide for more airflow and less plugging caused by tubeless sealant. The vulcanized base includes a raised center so that the sealant does not seep inside. The base is big enough to seal a schraeder valve and fits almost all rims perfectly. The valve core is removeable to easily inflate and add sealant. Speed Evolution valves are made from aluminum, making them half the weight of brass. The aluminum construction also makes it possible to anodize them. The valves come in gold, green, red and pink. They're the perfect accent to a customized bike.
Comment on Speed Evolution Aluminum Presta Valve
