Soul-Kozak
Specifications Weight74 gramsBearing Size6803 (2)Axle Diameter17 mmAvailable Drillings20, 24 holeHub Shell MaterialaluminumUseroad, time trial,...
$95.002 options.View
Specifications Weight, Shimano214 gramsWeight, Campagnolo194 gramsBearing Size, Shimano6903 (4)Bearing Size, Campagnolo6903 (2), 6803 (2)Axle...
$305.003 options.View
Machined 7075T6 alloy bar ends. Black with Soul logo laser etched. 48grams per pair 26mm diameter. 116mm length.
$90.000 in stock.View
Specifications Weight 21 grams/pair Bearing Size 606 Detail Soul Kozak's machined aluminum pulleys offer a simple, elegant option in aftermarket...
$20.000 in stock.View
Specifications Weight128 gramsBearing Size6903 (2)Axle Diameter17 mmBody and Axle Material7075 T6 aluminum Wheel Building Specifications Left...
$145.00 $108.75Save: $36.25 off
1 options.View
Ultra machined 7075 aluminum headset spacers. Convex external shape with very thin walls. Black with Soul logo laser etched. 10mm, 3.4grams 15mm,...
$9.003 options.View
Specifications Weight118 gramsBearing Size6902, 6805Hub Shell Material7075 T6 aluminumAvailable Spoke Drillings28, 32 hole Wheel Build...
$120.00 $90.00Save: $30.00 off
1 options.View
Specifications Weight245 gramsBearing Size6903 (4)Axle Diameter17 mmBody and Axle Material7075 T6 aluminum Wheel Building Specifications Left...
$335.00 $251.25Save: $83.75 off
1 options.View
Specifications Weight, Shimano195 gramsWeight, Campagnolo186 gramsBearing Size6902 (2), 6802 (2) Wheel Build Specifications Left Flange...
$300.00 $225.00Save: $75.00 off
1 options.View
The Soul-Kozak seatpost collar is one of the lightest at 10g (31.8). The collar utilizes 7065 series Aluminum with a stainless steel bolt. The collar...
$35.005 options.View
Specifications Weight, Titanium 41 grams per pair Weight, Steel 59 grams per pair Use road, cross country Detail Soul-Kozak's quick-release...
$40.00 $30.00Save: $10.00 off
1 options.View
This is one of the coolest top-cap designs we've encountered. The cap and bolt are one piece of CNC'd 7065 series aluminum. The end result is the...
$27.005 in stock.View
