Soul-Kozak Front Disc Hub
Soul-Kozak Front Disc Hub 28 Hole$145.00  $108.75
Save: $36.25 off
Notify Me When Available
Weight128 grams
Bearing Size6903 (2)
Axle Diameter17 mm
Body and Axle Material7075 T6 aluminum
Wheel Building Specifications
Left Flange Diameter55 mm
Right Flange Diameter41 mm
Left Flange to Center22.3 mm
Right Flange to Center28.2 mm
The latest iteration of Soul Kozak's front mountain hub gains some weight in favor of better durability and stiffness on the trail. Most of this weight gain is attributable to the use of larger section bearings mated with a relatively large straight 17 mm wide axle. Despite these changes, this Soul hub is still a very light 128 grams, and most certainly the lightest available in this price range. The brake rotor attaches via a standard ISO 6-bolt system.
As with all Soul Kozak products, these hubs are designed and manufactured in Poland, with excellent attention to finish work. The simple yet elegant machine work is topped with semi gloss black anodizing, Soul's logo and iconic evil jester are also laser etched on the hub shell as a finishing touch.
Assembly
We recommend that wheels built with Soul Kozak hubs be assembled by an experienced wheel builder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheel build here.
Comment on Soul-Kozak Front Disc Hub
