Seatposts
Specifications Weight 75 - 115 grams Available Diameters 27.2, 30.9, 31.6 mm Available Lengths 220, 290, 350 mm Tube Material Carbon Fiber ...
$700.00 $560.00Save: $140.00 off
1 options.View
AX Lightness' Daedalus seatpost is the lightest setback seatpost in the world. This post is suitable for road and cross country riding, with a rider...
$530.00 $450.50Save: $79.50 off
1 options.View
Specifications Weight 75 - 110 grams Available Diameters 27.2, 30.9, 31.6 mm Available Lengths 220, 290, 350, 400 mm Tube Material Carbon...
$590.00 $472.00Save: $118.00 off
1 options.View
Specifications Weight, L1100 grams Weight, L2110 grams Weight, L3130 grams Available Lengths220 mm(L1), 290 mm(L2), 350 mm(L3) Available...
$445.00 $356.00Save: $89.00 off
4 options.View
Specifications Weight~195 grams Available Diameters27.2, 30.9, 31.6, 34.9 mm Full Length400 mm Useroad and cross country About Enve Composites In...
$295.004 options.View
$295.005 options.View
Much lighter, simpler and more elegant than carbon fiber competitors. Graphics: laser etched. Clamp: AL 7075 T6 Ergal CNC. Tube: triple butted AL...
$164.004 options.View
Specifications Diameter34.9mm Lengths:75mm, 120mm Offset:0mm, 25mm Colors:Black, Gold, Red, Silver Weight:88-121 grams Material7075 Detail Kcnc...
$115.008 options.View
Specifications Weight, 27.2 x 350175 grams Weight, 27.2 x 400188 grams Weight, 30.9 x 350206 grams Weight, 30.9 x 400214 grams Weight, 31.6 x 350203...
$100.006 options.View
The Ti Pro Lite is KCNC's lightweight zero-setback seatpost. The main tube is machined scandium alloy, while the upper hardware consists of 7075...
$110.0022 options.View
Specifications Weight 80 grams Available Diameters 30.2, 34.9, 38.2 mm Adj Range 30 mm Tube Material Carbon Fiber Bolt Material 6-4...
$250.006 options.View
Specifications Weight 100-107gr Available Diameters 27.2, 30.9, 31.6 mm Available Lengths 250, 300, 350 Tube Material Carbon UD, 1k, 3k ...
$350.006 options.View
Specifications Weight, 27.2 x 300107 grams Weight, 27.2 x 350113 grams Weight, 31.6 x 300112 grams Weight, 31.6 x 350119 grams Setback20 mm Bolt...
$490.006 options.View
100% CNC Titanium bolts 27.2x350 Weight: 132grams Rider weight limit 90Kgs.
$128.00 $96.00Save: $32.00 off
11 options.View
Specifications Weight, 350 mm147 grams Weight, 410 mm153 grams Available Diameters30.9, 31.6 Available Lengths350, 410 mm Rider Weight Limit90 kg...
$150.00 $112.50Save: $37.50 off
9 options.View
Specifications Weight81.5 grams Inner Diameter30.0 mm Detail New Ultimate's seat mast top piece is one of the lightest available. In fact, this...
$210.004 in stock.View
Specifications Weight 123 grams - 166 grams Available sizes 27.2, 31.6 Color Options black or white Carbon fiber version...
$210.0013 options.View
Specifications Weight 135g (300mm) 179g (410mm) Available diamter 34.9 Available lengths 300, 410 New Ultimate has...
$220.003 options.View
Specifications Weight~114 grams MaterialUD matte carbon, UD carbon Available Diameters31.6mm Full Length350 mm Useroad and light XC Detail New for...
$260.004 options.View
Specifications M5 weight11.6 grams M6 weight12.6 grams MaterialAluminum Detail The Parts of Passion seatpost yokes are an inexpensive way to add a...
$32.008 options.View
Specifications Size Weight* 27.2 x 25095 grams 27.2 x 300100 grams 27.2 x 350105 grams 27.2 x 400110 grams 31.6 x 250100 grams 31.6 x 300105...
$510.008 options.View
Specifications Size Weight* 27.2 x 25080 grams 27.2 x 30085 grams 27.2 x 35090 grams 27.2 x 40095 grams 31.6 x 25085 grams 31.6 x 30090 grams...
$625.0011 options.View
The Starkes Stuck is one of the most popular choices for a lightweight, yet very solid seatpost for mountain bike and road applications. While the...
$143.0022 options.View
Specifications Weight74 grams Available Diameters30.25, 34.9, 38.35 mm Main Tube Material7075 aluminum Bolt Materialtitanium Setback1 mm (30.25), 2...
$155.0013 options.View
Many frames on the market today are manufactured with proprietary or uncommon seat tube IDs. Seatpost options are reduced drastically for these...
$15.007 options.View
