Seatpost Collars
Specifications Weight11gr.CollarCNC machined Ergal 7075 T6BoltCNC Ti Grade 5ColorsBlack, Blue, Gold, Green, Purple, Red Detail The Ultraclamp, like...
$40.0013 options.View
The KCNC Road Lite collar, is similar to the SC9 and SC11 collars, but utilizes a ti binder bolt in order to achieve incredibly light weights without...
$26.003 in stock.View
KCNC's SC10 mountain quick release seat collar features a unique bushing-less spherical cam. This system ensures consistently smooth and powerful...
$26.0011 options.View
Specifications Weight, 31.8 mm10.5 gramsWeight, 34.9 mm11.5 gramsWeight, 36.4 mm13.0 gramsWeight, 38.2 mm13.5 gramsWeight, 39.0 mm12.5 gramsCollar...
$24.0015 options.View
Ready for a simple, inexpensive upgrade? The KCNC SC9 seatpost collar may be exactly what you're looking for. Starting at a mere 12 grams for the...
$24.008 options.View
Weight 3.2 - 3.6 grams Compatibility 31.8 / 27.2 34.9 / 30.9 34.9 / 31.6 Material 6061 aluminum Colors Black, Blue, Gold, Green, Red, Silver ...
$10.0010 options.View
Specifications Weights31.8 - 7.6 grams, 34.9 - 8.5 gramsCollarCarbon FiberBoltCNC TitaniumTorque spec6 Nm maximum Detail The Mcfk seatpost collar...
$80.004 options.View
Specifications Weight 7 grams Clamp Diameter 34.9 mm Detail New Ultimate's colorful line of lightweight seat collars feature a simple,...
$30.006 options.View
Specifications Weights 7 grams Collar Uni Directional Carbon Fiber Bolt Titanium Torque spec 6 Nm maximum Purist Seatpost Clamp Details The...
$90.006 options.View
The Soul-Kozak seatpost collar is one of the lightest at 10g (31.8). The collar utilizes 7065 series Aluminum with a stainless steel bolt. The collar...
$35.005 options.View
Specifications Weight9 gramsCollar Material7075 AluminumBolt MaterialTitanium Detail Tune's precise attention to detail makes for immaculately...
$40.005 options.View
Specifications Weight28 gramsCollar Material7075 aluminumBold and Nut Material7075 aluminumLever Material6/4 titanium Detail Wurger translates from...
$70.001 options.View
Specifications Weight5.0 gramsAvailable Sizes28.6, 30.0, 31.8, 34.9, 36.4, 38.0 mmRider Weight Limit80 kg (176 lbs) Detail Tune's Skyline series of...
$100.001 options.View
