Scrub Workhorse Rotor
Scrub Workhorse Rotor 140 mm, Black$145.00 Notify Me When Available
Scrub Workhorse Rotor 140 mm, Blue$145.00  1 Remaining
Scrub Workhorse Rotor 140 mm, Cannondale Green$145.00 Notify Me When Available
Scrub Workhorse Rotor 160 mm, Black$145.00 In Stock
Scrub Workhorse Rotor 160 mm, Blue$145.00 Notify Me When Available
Scrub Workhorse Rotor 160 mm, Cannondale Green$145.00 Notify Me When Available
Scrub Workhorse Rotor 160 mm, Red$145.00 Notify Me When Available
Scrub Workhorse Rotor 160 mm, White$145.00  2 Remaining
Weight, 140 mm43 grams
Weight, 160 mm58 grams
Available Colorsblack, blue, green, red, white
Scrub's Workhorse Rotors are at once lightweight, durable, and functionally sound. Scrub Components developed a proprietary metal matrix composite material to achieve their superior balance of weight and function in their rotors. And at 55 grams per 160 mm rotor, these are among the lightest available, even when stacked against rotors with more exotic materials such as titanium and carbon fiber. Each Scrub Rotor is precision machined to ensure a flat braking surface, smooth outside edges, and solid bolt holes. The rotors are finished with paint on the non-contact surfaces, and are available in a variety of eye-catching colors.
These rotors, along with the entire Scrub Components line, are sourced and manufactured with pride in the USA.
Ordering
With these rotors, we highly recommend use of Scrub Components Pads. If these are unavailable, use only 100% organic or resin pads.
Comment on Scrub Workhorse Rotor
