Scrub Disc Brake Pads
Scrub Disc Brake Pads Avid Elixir XX$28.00 In Stock
Scrub Disc Brake Pads Avid Juicy$28.00  2 Remaining
Scrub Disc Brake Pads Formula$28.00  2 Remaining
Scrub Disc Brake Pads Magura$28.00  2 Remaining
Scrub Disc Brake Pads Shimano pre-2011$28.00 In Stock
Scrub Disc Brake Pads XTR 2011$28.00 Notify Me When Available
The material in these pads is specifically tested and designed for use with the proprietary metal material used in Scrub rotors. These pads are available to fit the most common brake calipers.
These pads, along with the entire Scrub Components line, are sourced and manufactured with pride in the USA.
Each package includes two pads for one brake caliper.
Please refer to your brake manufacturer's instructions for installation procedures.
Please note that sintered, semi-metallic or full metallic pads should never be used with Scrub rotors. Whenever possible, use these Scrub pads. If none are available, use only 100% organic or resin pads. Use of any other pad may compromise performance and/or void any support that we may offer.
Comment on Scrub Disc Brake Pads
