Scrub Components
Detail The material in these pads is specifically tested and designed for use with the proprietary metal material used in Scrub rotors. These pads...
$28.006 options.View
Specifications Weight 49 grams each Size 160 mm Detail The Scrub RaceDay is designed for the demands of mountain bike racing. The materials in...
$215.004 options.View
Specifications Weight, 140 mm43 gramsWeight, 160 mm58 gramsAvailable Colorsblack, blue, green, red, white Detail Scrub's Workhorse Rotors are at once...
$145.008 options.View
