Specifications| Weight | ~145 grams |
| Stem Clamp Diameter | 26.0 mm |
| Available Widths* | 40, 42, 44, 46 cm |
| Rider Weight Limit | 75 kg (165 lbs) |
*measured outside to outside
Geometry
| Compact, -5 degree | Compact, 0 degree |
| 42 cm | 46 cm | All Widths |
| Reach | 79 mm | 83 mm | 98 mm |
| Drop | 145 mm | 116 mm | 153 mm |
Schmolke Carbon was founded in 1993, shortly after Stefan Schmolke constructed the world's first carbon fiber handlebar. In the following years, rigorous safety and performance tests and use by top professionals such as Jan Ullrich and Erik Zabel proved that these lightweight carbon bars could easily outperform the best aluminum bars on the market. The TLO (The Lightest One) handlebar represents the pinnacle
of Schmolke's carbon development and sets the standard for light weight carbon road bars. In fact, few manufacturers even come close to reaching the weight class of a Schmolke handlebar.
Manufactured from T1000 carbon (a rating of the carbon's tensile strength, with the lower T700 rating as the bicycle industry standard), the TLO's unidirectional carbon structure is purposefully and meticulously hand laid to optimize strength and durability. The final woven carbon layer (available in 1k, 3k, or 12k varieties) is added for safety, but also does well in complimenting the handlebar's simple aesthetic. All Schmolke products are intensely tested for durability and safety, and the company possesses the utmost confidence in their product. Therefore, they provide a three year replacement warranty which covers defects in materials and manufacturing.
Ergo Design
Schmolke's Ergo design is best suited for riders and racers who desire an aggressive, traditional position. This design is marked by its deep and sharply angled ergonomic drops, as well as a lower, more aerodynamic brake hood position. The Ergo TLO is available in a 5 degree backsweep option, which brings the top of the bars slightly closer to the rider, allowing for addtional comfort when climbing by allowing a slightly more upright position.
Carbon assembly paste
is included with each Schmolke handlebar, and it is highly recommended that this paste be used to increase the security of the stem clamp and reduce the necessary bolt torque. Additionally, Schmolke only recommends use of four-bolt faceplate stems with their carbon handlebars. Please note that these versions of the TLO handlebar are not compatible with clip on aerobars, which require reinforcement in the carbon structure.
