Specifications| Size | Weight* |
| 27.2 x 250 | 80 grams |
| 27.2 x 300 | 85 grams |
| 27.2 x 350 | 90 grams |
| 27.2 x 400 | 95 grams |
| 31.6 x 250 | 85 grams |
| 31.6 x 300 | 90 grams |
| 31.6 x 350 | 100 grams |
| 31.6 x 400 | 110 grams |
*Weights are approximate and may vary slightly.
| Available Diameters | 27.2, 30.9, 31.6, 34.9 mm |
| Standard Lengths | 250, 300, 350, 400 mm |
| Tube Material | T1000 carbon fiber |
| Bolt Material | 6/4 titanium |
| Use | road only |
| Rider Weight Limit | 75 kg (165 lbs) |
Schmolke's insanely lightweight TLO seatpost range is manufactured to the highest standards of quality using the best carbon prepregs available in the market. The saddle clamp features eight points of contact for maximum security and load distribution. Additionally, the aluminum upper rail clamps are designed with chamfered edges which, combined with a large supporting carbon fiber lower rail clamp surface, ensures that carbon saddle rails are not unduly stressed. The M5 titanium bolts are designed as tension screws, strong enough take the stresses of aggressive riding and racing.
Schmolke seatposts feature varying wall thickness, contrasting with typical Asian-made posts which are cheaply manufactured with a constant wall thickness. The bulk of a TLO post's length is constructed with a mere 9 layers of carbon sheets, while the frame clamp section is reinforced with up to 17 layers. This design allows Schmolke to produce seatposts which are 50-100 grams lighter than competitors' seatposts of similar design, with no compromise in strength. To ensure the safety of all their products, Schmolke conforms to all current European testing standards, along with their own higher intensity in-house testing. Schmolke products are guaranteed to be free of material and manufacturing defects with a warranty period of 3 years.
Ordering
In their lightweight, efficient design, Schmolke's TLO seatposts have very specific ranges of insertion. These ranges, defined in the table below, are measured from where the seatpost enters the frame to the middle of the saddle's rails. It is very important that this distance be determined before ordering. Please contact us directly if you have questions regarding the correct sizing for you.
| Length | Insertion Range |
| 195 | 100 - 130 mm |
| 200 | 90 - 130 mm |
| 250 | 125 - 175 mm |
| 300 | 160 - 220 mm |
| 350 | 195 - 265 mm |
| 400 | 230 - 310 mm |
| 450 | 280 - 360 mm |
When mounting a Schmolke seatpost, we strongly recommend using the supplied assembly paste. This paste serves two purposes: to increase friction at the clamping point, thus reducing the torque necessary on the clamp bolt, and to protect the carbon from corrosion on metal frames. It is recommended that the post be removed, cleaned, and reinserted on a regular basis. The resin surface of the post is chemically highly stable, and will not be harmed by the use of standard solvents when cleaning. Torque at both the seatpost collar bolt and saddle rail clamp bolts should be limited to 3-4 Nm.
