Schmolke SL Carbon Seatpost
Sign Up For Our Newsletter
You're Signed Up!
Available Diameters 27.2, 31.6, 34.9 mm
Standard Lengths 250, 300, 350, 400 mm
Tube Material T800 carbon fiber
Bolt Material M6, 6/4 titanium
Use road only
Rider Weight Limit 75 kg (165 lbs)
Length / Insertion Range
250 mm 125 - 175 mm
300 mm 160 - 220 mm
350 mm 195 - 265 mm
400 mm 230 - 310 mm
Weight*
27.2 x 250 95 grams
27.2 x 300 100 grams
27.2 x 350 105 grams
27.2 x 400 110 grams
31.6 x 250 100 grams
31.6 x 300 105 grams
31.6 x 350 115 grams
31.6 x 400 125 grams
Product Manuals
Schmolke Seatpost Instructions
*Weights are approximate and may vary slightly.
Schmolke SL Carbon Seatpost 27.2 x 220 mm $510.00  1 Remaining
Schmolke SL Carbon Seatpost 27.2 x 250 mm $510.00 In Stock
Schmolke SL Carbon Seatpost 27.2 x 300 mm $510.00 Notify Me When Available
Schmolke SL Carbon Seatpost 27.2 x 350 mm $550.00 In Stock
Schmolke SL Carbon Seatpost 27.2 x 400 mm $510.00 Notify Me When Available
Schmolke SL Carbon Seatpost 31.6 x 250 mm $510.00 In Stock
Schmolke SL Carbon Seatpost 31.6 x 300 mm $510.00 In Stock
Schmolke SL Carbon Seatpost 31.6 x 350 mm $550.00 In Stock
Schmolke SL Carbon Seatpost 31.6 x 400 mm $550.00 Notify Me When Available
Details
Schmolke's range of SuperLight seatposts follow the same basic design as their lighter TLO series, with stronger saddle clamp hardware and a slightly heavier carbon layup. These seatposts are equipped with Tune's aluminum and titanium saddle rail clamps for the best combination of weight savings and durability. As a whole, the SL seatpost is only about 15 grams heavier than its TLO counterpart.
Schmolke seatposts feature varying wall thickness, contrasting with typical Asian-made posts which are cheaply manufactured with a constant wall thickness. The bulk of an SL post's length is constructed with a mere 10 layers of carbon sheets, while the frame clamp section is reinforced with up to 19 layers. This design allows Schmolke to produce seatposts which are 50-100 grams lighter than competitors' seatposts of similar design, with no compromise in strength. To ensure the safety of all their products, Schmolke conforms to all current European testing standards, along with their own higher intensity in-house testing. Schmolke products are guaranteed to be free of material and manufacturing defects with a warranty period of 3 years.
Ordering
In their lightweight, efficient design, Schmolke's SL seatposts have very specific ranges of insertion. These ranges, defined in the table to the left, are measured from where the seatpost enters the frame to the middle of the saddle's rails. It is very important that this distance be determined before ordering. Please contact us directly if you have questions regarding the correct sizing for you.
When mounting a Schmolke seatpost, we strongly recommend using a high quality assembly paste, such as Tacx Dynamic Assembly Compound. This paste serves two purposes: to increase friction at the clamping point, thus reducing the torque necessary on the clamp bolt, and to protect the carbon from corrosion on metal frames. It is recommended that the post be removed, cleaned, and reinserted on a regular basis. The resin surface of the post is chemically highly stable, and will not be harmed by the use of standard solvents when cleaning. Torque at both the seatpost collar bolt and saddle rail clamp bolts should be limited to 3-5 Nm.
