Schmolke
Specifications Size Max Torque Weight M4 x 160.8 Nm0.5 gramsM5 x 201.5 Nm0.7 gramsM6 x 304.0 Nm1.3 gramsM6 x 164.0 Nm0.7 grams Detail Schmolke's...
$20.005 options.View
Schmolke Carbon was founded in 1993, shortly after Stefan Schmolke constructed the world's first carbon fiber handlebar. In the following years,...
$575.003 options.View
Specifications Size Weight* 27.2 x 25095 grams27.2 x 300100 grams27.2 x 350105 grams27.2 x 400110 grams31.6 x 250100 grams31.6 x 300105 grams31.6 x...
$510.008 options.View
Specifications Size Weight* 27.2 x 25080 grams27.2 x 30085 grams27.2 x 35090 grams27.2 x 40095 grams31.6 x 25085 grams31.6 x 30090 grams31.6 x...
$625.0011 options.View
Specifications Weight~145 gramsStem Clamp Diameter26.0 mmAvailable Widths*40, 42, 44, 46 cmRider Weight Limit75 kg (165 lbs)*measured outside to...
$640.006 options.View
Specifications Weight~150 gramsStem Clamp Diameter31.8 mmWidth44 cmRider Weight Limit75 kg (165 lbs)*measured outside to outside Geometry Reach 95...
$640.001 options.View
Specifications Weight60 - 85 gramsAvailable Widths460 - 620 mmBack Sweep6 degreeStem Clamp24.5 mmFinish3k weave carbon Detail Schmolke Carbon was...
$330.005 options.View
Specifications Weight60 - 88 gramsAvailable Widths480 - 680 mmBack Sweep6 degreeStem Clamp31.8 mm Detail Schmolke Carbon was founded in 1993, shortly...
$350.006 options.View
Specifications Weight95 - 110 gramsAvailable Widths600 mm - 800 mmRise15 mmBack Sweep6 degreeStem Clamp31.8 mmFinish3k weave carbon Detail Schmolke...
$375.006 options.View
