Schmolke Carbon Bolts
Schmolke Carbon Bolts M4 x 16, Hex Head$20.00 In Stock
Schmolke Carbon Bolts M5 x 20, Countersunk$20.00 Notify Me When Available
Schmolke Carbon Bolts M5 x 20, Hex Head$20.00 Notify Me When Available
Schmolke Carbon Bolts M6 x 16, Countersunk$20.00  2 Remaining
Schmolke Carbon Bolts M6 x 30, Hex Head$20.00 Notify Me When Available
SizeMax TorqueWeight
M4 x 160.8 Nm0.5 grams
M5 x 201.5 Nm0.7 grams
M6 x 304.0 Nm1.3 grams
M6 x 164.0 Nm0.7 grams
Schmolke's carbon screws are manufactured in a highly specialized pressure extrusion procedure. The material used is Schmolke's own high quality Intermediate module fibers with PEEK-matrix. This is the only means to make sure the fibers are arranged in a spiraling pattern following the thread and centered towards the inside of the screw. The actual thread can not be stripped. In terms of dynamic strength carbon fiber is much superior to all other materials used for screws. They are stronger and 40% lighter than aluminum bolts.
Links
Schmolke's list of recommended uses
Comment on Schmolke Carbon Bolts
