Sapim Polyax Aluminum Nipples
Sapim Polyax Aluminum Nipples Black$0.45 In Stock
Sapim Polyax Aluminum Nipples Blue$0.45 In Stock
Sapim Polyax Aluminum Nipples Gold$0.45 In Stock
Sapim Polyax Aluminum Nipples Green$0.45 In Stock
Sapim Polyax Aluminum Nipples Purple$0.45 In Stock
Sapim Polyax Aluminum Nipples Red$0.45 In Stock
Sapim Polyax Aluminum Nipples Silver$0.45 In Stock
Weight0.38 grams each
Length14 mm
Material7075 aluminum
Compatible Thread2.2 mm x 56 tpi (2.0 mm spokes)
Sapim's series of lightweight aluminum nipples are manufactured from strong and corrosion resistant 7075 alloy. These nipples feature Sapim's Polyax design, a special profiling of the nipple's shoulder that allows the nipple to self align to the spoke's angle. This design helps to increase wheel reliability and spoke fatigue life.
Assembly
These Sapim nipples have a 0.127" square form on the inward facing side designed for traditional spoke wrenches. A high quality, well fitting spoke wrench should always be used to prevent damage to the nipple.
When building and truing wheels with aluminum nipples, adequate lubrication should be used to prevent galling and premature failure.
Recommended Tools
IceToolz Spoke Wrench
Alchemy Bladed Spoke Holder
Comment on Sapim Polyax Aluminum Nipples
